Question about Kenmore Elite HE4 Electric Dryer
Sud disply says SUD What should I do?
  • yadayada
    yadayada May 11, 2010
    call sears.
  • 5,911 Answers
This is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Posted on Apr 22, 2010
What does Sud mean?
Too much suds from possibly too much detergent or incorrect detergent.
Whats Causing your Washing Machine to Sud Mama Laundry Talk
Mar 20, 2016 | Washing Machines
Tip
Sud mean
over dose of detergent detectd during the wsh cycle ////// the motor control unit senses a suds lock condition by analyzing the current draw on the drive motor . if "sud" is displayed a potential suds lock is detected . this may signify a badpump an extra heavy load excessive detergent or excessive suds.................
on Aug 05, 2010 | Washing Machines
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
Why does sud appear
sud apears in a washer when the water does not drain fast enough cuz of the suds make sure to only use HE detergants so it wont make suds
Sep 05, 2011 | Kenmore Washing Machines
Machine read sud
SUD means too much soap was used. Run the washer with a few empty loads and no detergent and the SUD should go away.
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
