Question about RCA RCU600M Remote Control
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried batteries and universal remotes and could not get any codes to work. The buttons on the front of the tv do not work either. Then after a power outage it requires channel set up and the remote does not work. It is like the tv lost the code after I tried to program the direct tv remote to work volume and turning the tv on and off. This is a rca tv with guide plus
  • 666 Answers
Your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Posted on Apr 22, 2010
Cant get the remote to work for menu options just started setting it up already programed to my direct tv remote now nothing is working or either remote t.v or direct tv remote
To diagnose a remote control problem follow these steps.
1) unplug the TV power cord, count to five and plug it back in. (reboot)
2) try to power on with ORIGINAL MANUFACTURER remote.
if that works- your TV and original remote are fine.
if that does not work:
4) try to power on with buttons on the TV itself- if it works- check your remote batteries and try remote again.
Direct TV and Dish Network remotes will ONLY operate SIMPLE function of your TV such as power, volume, input.
They will NOT access your TV menu.
Apr 12, 2011 | Televison & Video
My remote stopped working. Replaced batteries so
1) Reset the remote. To do this, remove the batteries and hold down one of the number buttons for about 5 seconds to drain the capacitors. Replace the batteries, reprogram the remote to your TV and see if it works.
2) If it doesn't, try a second set of replacement batteries just in case.
3) If none of the DirectTV codes work, you have 3 options.
1) Contact Directv and see if they have additional codes not listed in the manual.
2) Contact your televisions manufacturer and see if they have additional codes to try.
3) Purchase a 3rd party remote that works with both devices..
Jun 03, 2009 | LG 32LB9D TV
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
frpm baldmeaney i unpluged my tv same model for 5 min and all was well again . this may work for you . good luck!
Dec 31, 2008 | Sharp LC52SB55U LCD TV
It sounds a lot like the internal IR receiver is bad; they can fail in different ways and they are not user replaceable.
Your set is made by Funai which has a mixed reputation for quality.
If you want to try an 'original,' check here to see if your model number is listed but be advised, the site is not cheap.
http://remotes.com/remotes/servlet/rs?a=Search&mode=brand&brand=Durabrand&uuid=12195878556250
Aug 24, 2008 | Durabrand DWT1905 TV
Remote codes for Haier tv sets
I saw the post above about an association with Hitachi and it worked for me. I have Haier model HL40XP1 and used the Hitachi code 10056.
Jul 15, 2008 | Televison & Video
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA RCU600M Remote Control Logo
231 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
