Question about Amana DLW330RA Top Load Washer
Amana washer doesn't spin, model dlw330raw, clothing was jammed at the top of the top, there is a burnt smell, it is abroken belt?
  • Amana Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
My Amana Washing machine model DLW330RAW makes a loud high pitch sound when on spin cycle. Could you tell me what it is?
loose drive belt ,if you have this noise then your clothes are not getting washed proply.adrian,,,,
Oct 30, 2010 | Washing Machines
I have an Amana Distinctions Washer DLW330RAW. I put a load in and in a couple of minutes had smoke. Shut it down and found the belt was broken and slightly burnt. I have replaced the belt but the...
The transmission is burned out. The same exact problem just occurred with my Amana Distinctions. Whirlpool will pay for this repair 'by concession'. Call the 800 number inside the lid and explain your problem, the operator should offer a free diagnostic visit and the repairman should offer free repair.
Aug 13, 2010 | Washing Machines
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Amana AL480DAW- burnt smell, smoke, still fills then dicharges
You are right on about the belt. If the tub every gets jammed by a full load and has trouble turning, the drive belt can get heated up ( kind of like spinning tires on the road...you get a smell and everything still works).
I would suggest pulling the front cover to expose the belts...look underneath. There are usually two one for the drive and one for the pump. I'd replace them both... with extreme heat, it can change the belt enough that it won't operate correctly with bigger loads.
K
Jul 10, 2009 | Amana ALW480DA Top Load Washer
AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
Amana DLW330RA Top Load Washer Logo
442 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
