Question about NEC AccuSync AS120-BK (Black) Monitor
The problem is that it is not Degaussing
The problem is that it is not Degaussing.
Thanks
Jose
Note: If it is possible to have the electronic diagram it would be nice.
    President:
  • 1,768 Answers
1. You may be able to obtain a schematic at this site if you do a Google search. ESI
Troubleshooting a degaussing circuit is very tedious but good luck!
I hope this helps.
Posted on Apr 23, 2010
WHERE IS THE REMOTE COMPASS MODULE ON A 2008 JEEP COMMANDER
wow no symptoms stated just the boring where is it...
but great question, names car and year, clearly
we've posted the full fsm online here 100s of times.
here we go again.
down load it, then type , (after opening it)
control F, the type compass.
i wonder if a compass car has compass , omg.
i have 2010 and have same book.
did you scan the PCM yet, i bet not.
and its guess what, telling why it fails right now.
see page 8M-6 in book FSM.
the dtc shows car needs degaussing,, now.... see?
and if that error happens the compass goes blank, RTM?
8m-20
calibration, RTM
replacing first is "overthetop", why go there.
first are scans then tests.
or needs just a degaussing... (a tool)
page 27
"NOTE: In addition to the Universal Transmitter
operation the Electronic Overhead Module (EOM)
is responsible for some of the compass functions.
Anytime the EOM is replaced the compass variance
value must be set, (Refer to 8 - ELECTRICAL/
OVERHEAD CONSOLE/ELECTRONIC VEHICLE
INFO CENTER - STANDARD PROCEDURE - COMPASS
VARIATION ADJUSTMENT)."
not only that the PCM can lose commmications with this OEM.
so not scanning all modern cars, is a road to doom.
why skip scanning the car first and checking fuses.?????
scan first
ask questions 2nd.
my motto.... and WIN
Dec 31, 2015 | 2008 Jeep Commander 5.7
I need a vacuum line diagram for a 1984 cadllac coupe deville
Fig. 31: Vacuum circuits - 1984 V8 4.1L engine Fed. and High Alt. (DFI)
Fig. 33: Vacuum circuits - 1984 V8 4.1L engine Calif. (DFI)
Hope helps. Just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment. Have a nice weekend and thanks for using FixYa.
Jose.
Oct 18, 2011 | 1984 Cadillac DeVille
Sony FD Trinitron WEGA KV-34HS420 34" TV Last week the picture on the left and right of the screen started to go purple. It was about 2 inches from the outside that it did it. It went back to...
It is most likely a degaussing issue - replace the PTC thermistor (this is usually a 3-pin device located near the fuse in the power supply board; each has a different part number for different TV models and tube sizes) - check for dry solder joints on it first though, if they are intact, note the part number, as well as its reference on the PCB, order a replacement, fit it (they usually only fit one way on the board). I doubt this model uses electronic degaussing so the part itself should be easy enough to get hold of.
It might also be a good idea to borrow an electric degaussing wand from a workshop as well if you can, to fully remove the extraneous magnetic fields around the tube. This should hopefully solve your purity problem.
Feb 14, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
We have a panasonic ct-36d31e that has developed a degaussing problem now. Rainbow colors - magnets haven't helped neither has power drill placed near the screen. Is there a degauss button on this model...
Hi Tracy,
Unfortunately magnets etc will most likely do all but improve the problem. When a T.V set is turned on it automatically degausses (demagnetises) the tube. However, if the screen does not degauss, its most likely a small electronic component in the degaussing circuit which has burnt out. This component is usually black in color, is rectangular and about the size of of the T.V. screen displayed alongside your question. Its inexpensive to replace(less than $5) and can be found at most electronic component stores.
Please let me know if I can be of any further assistance.
Best wishes,
Graemevm
Dec 23, 2009 | Panasonic CT-36D31 36" TV
Magnavox 20mt4405/17 piece of junk!
Hello sletak, This problem is actually common. Your degaussing coil has malfunctioned, causing the power supply to become unstable which in trun is effecting the memory settings in the processor. You have threen problems in one so lets start by looking at the overall cause first 1) degaussing coil going bad (shorted then opened) Replace this and the thermistor that is attached to the degaussing circuitry. 2) power supply instability (power surge from the degaussing circuit) replace the damaged components in the power supply section. Troubleshoot this thoroughly. 3) after fixing the power supply and the degaussing components you will need to manually degauss the TV and then use the auto-degaussing function to do the rest. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Philips Magnavox 20MS233S 20" TV
Degaussing a NEC LCD1700M+
LCD type monitors don't use a degaussing coil. Older CRT type monitors used/needed a degaussing coil built around CRT for de-magnetizing.
Jul 20, 2008 | NEC LCD1700M+ Monitor
Wiring diafram for Gaggia cubika
What kind of Gaggia do you have?
Jul 10, 2008 | Coffee Makers & Espresso Machines
How do i degaussing a dell e550 color monitor usung its built in degaussing system?
Hi - Your monitor has a built in degaussing feature that executes every time you turn the monitor on. To perform extra degaussing, turn your your monitor off for at lest 30 minutes then turn it back on. This will cause it do a more thorough degaussing as opposed to just turning your monitor off and then turning it right back on. If this answered your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 06, 2008 | Computers & Internet
Computers & Internet Logo
104 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
