Question about Kenmore Sewing Machines
I have a new kenmore sewing machine model 385.15358. I can't wind the bobbin
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
  • 323 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
sewman7
Posted on Jan 23, 2009
SOURCE: Bobbin won't wind
I also have the 15358. You probably forgot to "lock" the bobbin winder. After you put the bobbin case on it's peg, push the peg to the right until you hear a click. Then after you disengage the clutch, the bobbin will wind.
Posted on Feb 15, 2009
bargainbox
  • 1388 Answers
SOURCE: Model No. 15358. I am having problems with my
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Posted on Sep 04, 2009
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
I cannot wind the bobbin on my old Sears Kenmore 1802 Sewing machine. Help!
put bobbin place and loosen the hand wheel .on the right end of machine
Apr 09, 2015 | Kenmore Sewing Machines
My kenmore sewing machine won't wind the bobbin on. The motor runs but the bobbin is not engaged.
Not all models are the same.
You will have to refer to the manual to see what needs to be engaged or disengaged.
On some machines, this is loosening the center knob on the handwheel and moving the bobbin pin to the right or the winding knob to the left.
There are threading/bobbin winding guides sewusa.com where you may find your model or one that is similar.
Mar 21, 2010 | Kenmore Sewing Machines
BOBBIN WINDER WON'T WIND
bobbin wont wind on sewing machine
Apr 03, 2009 | Kenmore Sewing Machines
Can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Dec 22, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
55 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
