Question about Amana AFB2534DE Bottom Freezer French Door Refrigerator
Refrigerator not staying cold freezer is fine
This happened 3 months ago and the coil was all frosted up. service man defrosed the coil and said this would never happen again. here we go again, there must be something wrong. this machine is a little over 1 year old. Help !
  • Amana Master
  • 43,501 Answers
Posted on Apr 23, 2010
Freezer fine, fridge not cooling
This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
Mar 10, 2014 | GE GTS22WCP Top Freezer Refrigerator
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
The self defrosing fridge freezer is freezing and leaking inside of fridge, 3 weeks ago I melted ice in freezer and drain with hair dryer, worked for 3 weeks, now freezes agin?
You have a problem with the defrost system. There 3 components... heater, thermostat, and timer or adaptive defrost control depending how old your refrig is. Check heater and thermostat( located on the evapotator coils) with an ohm meter. The heater will have some resistance and the thermostat will be closed(must be cold). If these check good replace timer or adaptive control.
Mar 24, 2010 | Refrigerators
Refrigerator won't stay cold but freezer works fine.
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Refrigerator wont stay cold.Freezer works fine,no frost buildup
i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 27, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
The coils under the freezer keep getting built up with solid ice so the fridge will not stay cold? Defrosted everything about a month ago when it happened the first time????
Hi, You will need to unplug the defrost drain hole located inside the freezer section under the evaporator coil. Remove the rear panel in the freezer and you can get to the drain. Please let me know if this helps you or if I can assist you further.
Vic
Jul 15, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Freezer cold, but Fridge only a little cool
Sounds like you have a defrost problem either the Timer /Heater or Bi-metal stat is bad. you can unthaw and the unit will work fine for about a week until it frosts up again Where was this screw they said was loose?? have them check the defrost system.
Aug 28, 2008 | Haier HRF10 Top Freezer Refrigerator
Amana refrigerator only not working
Model # important.
You have a failure of the defrost system. There are 3 components not counting wire and connectors. Most likely it is not the heater that leaves the defrost timer then the defrost thermostat. My guess is that the defrost thermostat is bad (just a guess for now) Need more info to help you more. If you know what and where the defrost timer is then advance it clockwise till you hear a distinct click, not the little clocks you hear during turning it, a distinct click. If after about 10 minutes you notice the frost down low on the freezer rear interior wall melting. Replace the Timer it is bad.
If this makes no difference then I am betting you have a bad defrost thermostat and it is located on the top right part of the freezer cooling coil behind the rear interior wall of the freezer behind the frost.
supertechks
Nov 21, 2007 | Amana ABB1927DE Bottom Freezer...
Amana AFB2534DE Bottom Freezer French Door Refrigerator Logo
128 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
