Question about LG DLE5977 Electric Dryer
LG DLE8377NM dryer is working but not heating, cleaned out all the lint and the vent lint, still no heat
  • LG Master
  • 43,501 Answers
If you have a gas dryerLG DLE8377NM dryer is working but not heating - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 23, 2010
Dyer will not heat
Sounds like an open heating element issue. If you have two sensors for internal temps, the chances of both going bad at same time are remote.
Locate the element wiring and disconnect from circuit and do a simple continuity test. Chances are that it is burnt out or open.
Jan 28, 2014 | LG DLE7177 Dryer
LG Tromm dryer dryer number DLG3788W is not heating. it spins and works perfectly accept it stopped heating yesterday. I took off the vent hose yesterday and cleaned out all the lint there, it wasnt too...
Either there is a fault in the power supply to the heating coils, or the heating coils have burned out. A multimeter will come in handy at this point to check continuity across the terminals to the heating coils, and to test current supply to the coils. Be very very careful since you are dealing with 220 volts. If you do not feel comfortable doing it yourself, call an appliance repairman.
Oct 02, 2013 | LG DLG3788W Gas Dryer
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
LG Tromm DLE8377NM check filter but filter is clean
You say lint hose is disconnected. Are you referring to the exhaust vent to the outside? I would suspect this vent is clogged or a vent flapper outside may be stuck shut.
Feb 14, 2012 | LG Dryers
Unit powers up, check filter light flashes until you turn main control knob to any setting (e.g 'normal'). Press start, unit runs, but no heat. Checked output of vent outside, plenty of cool air is flowing...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | LG DLG5988 Gas Dryer
Turn dryer on and it starts to heat up and then the heat stops and within about 2-3 minutes will start to heat up and then the heating up stops.
Clean out the exhaust vent tubing really good.. A moister sensor will detect any build up of lint and shut the heat off
Jun 03, 2010 | Dryers
No heat
check the vents ductwork It maybe clogged up full of lint causing the heating sensor to work properly. If clogged up and cleaned it will work again for you
May 01, 2010 | LG DLG5988 Stainless Steel Gas Dryer
No heat
Check the vent hose from the lint screen all the way to the outside flapper many calls I get of no heat on dryers is from people putting stockings over the vent in the winter and then back to the vent in the summer but what happens is that they don't clean it every week or more and it now builds up in the dryer blower and when hooked back up the the vent it blows a big glob of it and it then blockes the vent, this is also very dangerous because dryer lint is very flamable. Be sure to disconect power before cleaning the hose and blower in the dryer.
Jan 28, 2010 | LG DLG3788W Gas Dryer
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
LG DLE5977 Electric Dryer Logo
534 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
