Question about Car Audio & Video
I got the switch hooked up and got picture but i dont have a remote to do the code for the screen to play all the time what can i do besides keep this switch hooked up i would like to permanatly keep it working
    President:
  • 1,469 Answers
The only solution to the problem is that, you will need to get a remote for it.There is no other way to operate it.
Take care.
Posted on Apr 29, 2010
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
Is it okay to hook up my playstation system to my projection tv?
It's OK as long as the picture keeps moving. Besides, that is for projection televisions not for LCD or DLP's
You should be fine.
I hope that this helps.
asnowman
Oct 01, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Resolution Problem!!
If you have the same monitor as when you bought the PC do a default reset. should take care of it. If you have a new monitor, just keep tweaking it. you'll get there. play with the settings.
Feb 24, 2009 | Dell Computers & Internet
I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
please donot forget to rate this solution.
Thanks for using FixYa.
Jan 28, 2009 | LG RC199H DVD Recorder/VCR
Vm9312 in dash will not play video
Go to your radio tuner screen and go to your set up page then use your remote and press 5,4,3,2,1,0 and hidden menu will pop up then you will have to press the tool looking button on the left side of the screen and it will give you an option to it off so you dont have to hook up the pink wire.
Nov 17, 2008 | Jensen's VM9312 Car DVD Player
Require region unlock code for LG RC389H
1.Switch on unit
Oct 19, 2008 | Televison & Video
Blue screen
It sounds like your kid switched to a different input. I am not sure what you have hooked up where but on your remote at the top there are two buttons - one is labeled HD.S and other is SD.S - I do not have my remote handy but am going from memory. The HD.S button switches to the hi-def inputs and the sd.s switches to the standard definition inputs. Try pressing these and switch around until you see a signal again. You will need to let the input "stabilize" and the picture appear so when you switch inputs give it 10 seconds or so before moving on.
Aug 06, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
