Question about Dell E171FPb 17" Flat Panel LCD Monitor
Black screen when the power is on.
We push the power button on the 171FP Flat Panel Display '03 and the green light keeps flashing and the screen stays black. In the manual it said to push any key or move the mouse but that also doesn't work. Do you have any suggestions, or answers?
  • 11,361 Answers
Common failure in the Dell are shorted transistors or bad caps in the inverter ccircuits, bad solder joints, bad caps in power supply. I would try it on another PC first, if it still does not work, you will have to open it up. Please look through my pictures of failed Dell moniotrs to get some ideas.
http://s807.photobucket.com/home/budm/allalbums
Replacement board: http://www.lcdrepair.us/e171fpb-power.html
Please post back what you find.
Posted on Apr 23, 2010
My Phillips 42PF7320/79 Flat Panel TV won't turn on, screen stays black but green pwr light is on, after a lil while the green light flashes a couple of times then goes off itself completely
This idea may be worth a try. Look at the buttons on your remote. If you see a button that is marked "TV" give that button a push and then give the "Power" button a push. Wait for a while! sometimes this takes a while to turn the TV on or off. You may have to do this a couple of times depending if the power was off or on when you started doing this. If you started with the set off, sometimes it takes a while for the set to turn on.
Jan 04, 2015 | Televison & Video
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
My monitor has power but the screen does not have a display no matter what control buttons I push
When i plugged in my sva lcd monitor it was all black but the green light was on,so i reached around the back and tightened up my cords and it came on :)
Jan 14, 2012 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Princeton VL1715-1 no display
From what you say there is probably not much you can do with it, the parts inside are SMD, to small
to work on. If you could still see txt on the screen when you shine your torch, it could be fixed by
replacing the back lighting PCB.
Hope this helps
Have a nice day.
Dec 22, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dell E171FPb 17" Flat Panel LCD Monitor Logo
150 people viewed this question
Alun Cox
