Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades will not engage when lever is engaged.
  • soonerborn43 Apr 23, 2010
    That would be manual. I'll check the belt. Appreciate your prompt solution.
  • 23 Answers
Is that the manual one or the electric pto? can you see if the belt is on all its pulls?
Posted on Apr 22, 2010
Engine starts idle well and sshut off when attempt engage blades
Chances are one of two sensors is broken or out of adjustment.
Either will cause engine shutdown when blades are engaged.
The first is the seat sensor. If you rise out of the seat with the blades engaged, the engine will die. That sensor is usually a switch located under the seat. The second is the Reverse lever (Or gear position). Newer tractors will shut off if operated in reverse with the blades engaged. This sensor may be more difficult to find, but it is usually another switch located around the gear shifter (or hydrostatic control lever).
Jul 06, 2015 | Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
When I engage the lever for the blades to start cutting, the blades don't engage
Check for bad or loose belt also see if you are missing a shear pin in one of your drive pulleys. See if your lever to engage the blades is actually putting driving pressure on the belt. Could be a spring is missing as well.
Apr 12, 2015 | Garden
Why won't blade engagement lever move?
The cable is rusted,not allowing it to move,or there is something jamming the mechanical parts on the deck.
Oct 19, 2014 | Garden
Why don't the blades engage?
Blades Engage via a pully system. Once you move the lever to engage the blades, the belt tightens and the blades engage. It is possible that your belt is broken or has gone out of track with the pulleys. If you know the belt is ok, then it is probably a bearing in one of the blade mounts.
Aug 12, 2014 | Garden
I have a 42" mtd lawn tractor. The blades do not
The blades engage via a belt, that goes around a series of pullies, one of those pullies is a tension pulley that is connected to your pto lever by springs, the engine has nothing to do with your blades until after you engage the lever, I would check your belt. It could be loose, and if you engage the blades it could take it a few to get up to speed, thus making it seem like its only when the engine is warm.
Does everything else work fine? As in the tractor moves when the blades are not engaged?
Jul 11, 2012 | Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
John Deere L110 blade brakes wont stop blades from spinning
Are the brake pads on brake levers good? May need replace levers.
Apr 01, 2012 | Garden
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Lever that adjusts height does not make blades turn. You need to engage the blade lever and if you can not tell if the blades are turning then they probably aren't. check belt it could need replacement.
Apr 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
255 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
