Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 2.0 Model JVM2070SK02 no power - I have tried plugging it into different outlet - still no power - no display - any answer will be appreciated
  • 389 Answers
You need to find a handy dandy fellow or lady and take the back off. You may need a special screw driver type tool in the allen wrench catagory. The screw may have a post in the center. They carry these type of allen wrench tools at the hardware store. Get the kind that has several different sizes on it It cost a little more but you won't be sorry later.
Once you get the back off you should see a white fuse. This is the first thing to check. You may not have that amperage of fuse laying around the house in your drunk drawer. Just to test it out wrap some aluminum foil around the fuse and plug it in and if you get power on the lights then that is your problem. Unplug it until you get the right fuse at the same hardware store. You don't want to have any sparks flying or wires burning. The aaluminum foil just gives you a temporary test at best. And it is also all I can offer you in help on microwaves. Except to check and clean your fan while your inside of it. Let me know if I got lucky and please leave me a thumbs up for the effort. Raz
Posted on Apr 23, 2010
The touch pad glass (behind a layer of plastic) has shattered. Is there a way to replace this part without paying for the entire part # 130 as described on the parts sheet?
Posted on Aug 16, 2011
"ge spacemaker microwave oven model jvm1530"
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt http://www.microtechfactoryservice.com/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2013 | Microwave Ovens
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Model JVM2070SK02 does not heat. Everything else works on microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1653 sho1 display disappears while cooking and shutsdown microwave.Reset display and would function fine for a while. Started to happen once in while now so frequent that oven no longer...
See this FixYa solution. even if your model number is different.
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cuts off after 2 seconds
Just a hunch; plug it in to a different outlet.
AC outlets are only marginal when new and that unit can draw well over 10 amps.
If the contacts are failing, the unit will think it has been disconnected, killing off the clock setting too.
If that doesn't help, try plugging another high power appliance, an iron, toaster or coffee maker, into the same outlet used for the GE to see if they behave normally.
Jul 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven JVM1330BW200
all...you should first check to make sure the outlet you're using is good. Really. Next, check internal fuse and thermosafety in the unit. They are both found inside the button area. The safety is about the size of a dime and 3/8 inch thick with two wires. Sometimes they open. They should be continuous. Not it? Let me know.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
539 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
