Question about Lebijou Home
I have a Le Bijou Bergamo toilet (model# v-790) that needs a new flush valve assembly. Does anyone know where I can obtain one or know of an alternate brand that will fit this toilet? Thanks
  • 4 more comments
  • cwing8 Apr 23, 2010
    I spoke with Action Supply today, and they did not have any Le Bijou toilet parts. Do you have any other suggestions? Thank you
    Cheryl
    I spoke with Action Supply, and they did not have Le Bijou parts. Do you have any other suggestions? Thank you
    Cheryl
    I spoke with Action Supply and they do have access to any Le Bijou parts. Do you have any other suggestions? Thank you
    Cheryl
    Luxury Home Products did not stock any Le Bijou parts either.
    No luck with eFaucets in getting Le Bijou parts.
    Cheryl
  • cwing8 Apr 26, 2010
    Hello again, Taran
    No luck with Quality Bath.com for the part.
    Cheryl
  • 10,515 Answers
Try to Contact :-
http://www.actionsupply.com/catalog/c104.html
You could Chat with them.
Toll Free Tel (866) 232-8238
Toll Free Fax (877) 684-4730
If still unable to Find the same or alternative, revert to me and i would be glad to check more options.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 22, 2010
  • 2 more comments
  • taran_2005
    taran_2005 Apr 23, 2010
    Thanks for your response!!
    Try :-
    http://www.luxuryhomeproducts.com/lebijo...
    Phone Number - Toll free 1-888-880-9469
    (9am-4pm EST)
    further assistance.
    Hope i helped you.
    Thanks for using '
  • taran_2005
    I have one more Big Vendor. You could also try that :-
    http://www.efaucets.com/
    Phone Number - 1-800-891-0896 Mon - Fri ( 8 AM - 9 PM CST )
    further assistance.
    Hope i helped you.
    Thanks for using '
  • taran_2005
    Never knew, it would be so tough to get parts for this Brand. Try :-
    http://www.qualitybath.com/brand~brand~L...
    Phone Number - 1-800-554-3210
    further assistance.
    Hope i helped you.
    Thanks for using '
  • taran_2005
    taran_2005 Apr 26, 2010
    As of now, there are no more Shops or Vendors i knew of other than what i offered.As of now, i have no more references. But, i am looking for more Vendors, and if i would come across, any of the Vendors who actually keep these i would let you know.
    Thanks!!
How do I change a flush valve on a Kohler toilet K3496
Remove tank from bowl and take the nut off were the water inlet goes the assembly will come offf and reinstall the new valve
Sep 25, 2014 | Kohler Home
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
A small intermittent water leak in the flapper flush valve unit which also causes "water hammer" in the copper piping in the basement. New flapper valves did not solve the problem Sanding...
Older Eljer toilets are good for this and yes you need to replace the complete flush valve assembly. I would recommend putting in a fluid master system as they in my opinion are the best. Their kits come complete with everything you need to do the job and provide excellent instructions and if that is not good they have videos on their web site. The site is slow to load but worth waiting for.
http://www.fluidmaster.com/
Mar 08, 2011 | Eljer Home
Have old kohler, i do not know what the inside flapper part is. However toilet will flush but tank will not fill. I can turn thhe water to the tank off and turn on again and it will fill
This indicated that there is dirt of corrosion in the flush valve assembly that get jarred loose and flushed out when turning on the supply valve below. My recommendation is replacing the flush valve assembly with a Fluidmaster flush valve. Be sure to follow the instructions when removing the old valve and installing the new one. If you need step by step instructions, please message me and I will provide them.
Dec 05, 2010 | Kohler Home
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
Can't install new Kohler rialto Flush Value
First things first, remove the fill valve, and the flush handle mechanism. This will give you plenty of room to work with the flush valve. Before installing flush valve lubricate tabs with plumbers grease. Now put on a pair of work gloves, pushed down very hard and turn the tabs should slide easy because of the grease. Remember do not alter the gasket, the gasket needs to be compressed to do its job. I know removing the fill valve and the flush handle seems like a pain, but there is no way to get your hands in the proper position to install the flush valve assembly.
Apr 25, 2010 | Kohler K-3386-0 Rialto one-piece...
Igenium Flushing valve will not shut off.
THE WHITE PIECE IS LOCKED IN YOU MUST PUSH DOWN AND TURN A HALF OF TURN .THEN LIFT IT OUT,DON'T DAMAGE YOUR O RING
Apr 05, 2010 | Kohler K-3422 - Wellworth Elongated...
What is the procedure for replacing the flush valve assy on a san raphael toilet. it is a one piece tank and bowl assy and must install from the inside of the tank. it appears to possibly rotate into place...
If you purchase the flush valve from Kohler, it comes without instruction. Rotation is the key to removal. First note the exact orientation of the assembly before attempting removal. Unhook the flapper chain and remove the flapper. The old assembly does indeed rotate in either direction for removal. I used a counterclockwise motion. (it was a tough turn, don't break the bottom of the bowl where the valve seat is located.) Then install the new foam gasket on the assembly. The new assembly is replaced in the reverse manner. I removed the new flapper from the flush valve for ease of install. You must put significant downward pressure on the flapper seat while rotation is accomplished. Orient the assembly as was the old one. Replace the flapper, connect the chain and observe the flapper for proper opperation.
Oct 03, 2009 | Kohler K-3384-2-0 San Raphael elongated...
Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
Can't remove old assembly...stuck in there
You have to remove the tank bolts on either side of the flush valve. Once you remove it, there is a tank to bowl seal that will need to be replaced. Remove the old seal and there will be a huge plastic nut that holds the flush valve to the tank. Remember to use new hardware when reassembling the toilet so that it won't leak sooner rather than later!
Apr 03, 2009 | Crane Plumbing Toilet To Go Tall...
Home Logo
Top Lebijou Home Experts
Donni Steen
Tom Chichester
Are you a Lebijou Home Expert? Answer questions, earn points and help others
