Question about Epson Stylus C60 InkJet Printer
New ink cartidges..text not printing on paper
SOURCE: ink doesn't show up
same problem as above.
Posted on Nov 03, 2008
jacklee366
  • 541 Answers
SOURCE: Flashing red lights
this means your printer wast pad is full but your printer can be reset let me no and i will send you the info on now to reset your printer
Posted on Feb 19, 2009
southtree
  • 5 Answers
SOURCE: printer is not printing text
If the printer was unused for a week or 2 the print heads are clogged with dried up ink. You can use the maintainance tab for the printer for cleaning and nozzle check or the program below. I have been using it for several years.
This is a utility to manage your ink. Gives an accurate count of how many ink shot are left in each cartridge. The printer just told me I need a new magenta but this program says I have 13% left. It also has sepparate routines for cleaning the black and color (unfortunately not individual cartridges) and a powerful clean cycle when they are really cogged.
http://www.ssclg.com/epsone.shtml
Posted on Jul 19, 2009
cns assoc
  • 677 Answers
SOURCE: DX4450 goes through motions of printing document
Did you just install the Ink Cartridges? If yes, did you take off strip?
Shut it down and wait 15 minutes, then turn back on.
Good Luck
Posted on Nov 04, 2009
  • 10 Answers
SOURCE: i have an epson nx105 -put new ink cartidges in
sounds like maybe the computer cant see the printer. check cables and reinstall software and drivers
Posted on Jan 15, 2010
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
My printer is printing faded text
your ink at cartridge will empty, refill ink at your cartidge, or change with new cartidge
Jan 19, 2011 | HP Photosmart C5180 All-In-One InkJet...
Ink cartidges are all installed and registering ok. New balck ink installed but will only print in colour and not black print what can I do as I need docs printed urgently?
Does it take (pull up the paper) in the paper? If so, Try to print only images and check if it works or not. It'll be much easier if you let us know the program from which you are printing. Also try to print only in text using Ms Word, wordpad or notepad. If possible update your driver. Good luck.
May 26, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Hp officejet 7110
1st how old are the cartidges ink could be solidified.
2nd did you take the plastic off of the new ink heads?
try runninng clean pint heads from printer control
Jan 04, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
Epson Stylus C60 InkJet Printer Logo
19 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
