Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
There is no suction to our Dyson animal (purple-approx 8 yrs old)
We have taken all of the parts off and caefully and securely reattached. Also cleaned the spinning carpet brush of all hair, etc.
    President:
  • 1,871 Answers
Hello bnsbryan :
1: Check that the Dyson's brushbar knob is turned to the "Carpets" setting for vacuuming non-delicate and raised pile carpet. Vacuuming carpet on the "Bare floor" setting usually leaves a telltale single wheel mark on the pile, and pickup is severely limited.
2:Locate the removable filter on the side of the vacuum. It will be marked with a raised circular representation.
3:Press down on the release button with your thumb as you lift filter housing up and out
4:Examine the filter for debris. Wash the blue foam and yellow framed filter in cold water. (See Tips section.) Let dry for 12 hours. Do not wash the outer filter housing that snaps into the vacuum; simply wipe clean with a dry or slightly damp cloth. Replace the filter when completely dry.
5:Locate the airway inspection valve on the opposite side of the vacuum. Press the release button as you lift the valve up and away from the machine.
6:Remove any debris or clogs you find inside.
7:Use a soft cloth to clean up lighter debris and completely clear the airway valve.
8:Tip the Dyson vacuum over to find the U-bend at the back of the unit. Press the release button as you pull the U-bend down and away from the machine.
9:Inspect the U-bend and remove debris. Be sure to line up the release button as you snap the U-bend back into place.
10:Check all removable pieces to be sure they are attached properly and snapped correctly into place. The soleplate should be flush with the cleanerhead.
What you need for this :
  • Large slotted screwdriver
  • Scissors
  • Washcloth
  • Soft cleaning cloths
  • Household surface cleaner, safe for plastics
  • Crochet hook or similar long-handled tool
Warning :
Unplug the vacuum before doing any troubleshooting. Follow all manufacturer's instructions and warnings. The yellow encased filter and blue foam filter pad can be submerged and rinsed in cold water only. Do not use detergent. Do not wash or dry in dish or laundry machines. Do not dry in the oven or microwave.
PLEASE RATE !
Posted on Apr 23, 2010
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
Suction is terrible
First be sure that all parts are securely attached, even removing and reattaching can help ensure a properly seated connection. Next check to make sure the filters are clean. Finally check the carpet beater head, to make sure it's free from hair and other debris.
If none of this works, call or email Dyson, even if your warranty is expired, they maybe able to help out further. They have GREAT customer service!
Jan 03, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Animal, purple ball, no suction upright
you might be missing a blockage in the hose from the brushes to the dust collector Take apart the hoses and check
Jul 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal does not have enough suction from the wand handle to power the mini turbine head. The wand handle has very little suction.
Hi its Darran at Dyson.
It sounds as though your wand/hose assembly is blocked. Try following the blockage procedure in your user guide or visit our website's support section where you can use our self help guide to diagnose problems.
www.dyson.com
Kind regards
Darran
Dyson Customer Service
Mar 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson is making an airy sound a few seconds after it starts working. The suction way degrades after this.
check the large rubber seal at the bottom of the cyclone. if there is a gap between this seal and the bottom of the canister then dirt has passed through the motor. chances are the motor is shot. This was a design flaw so it should be covered under warranty if its less than 5 yrs old
Feb 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Need to replace the suction hose, need help reattaching
You need to purchase a new hose - you can search for it online (DC07 External hose) or you can simply call the Dyson helpline and order it through them.
Jul 13, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal with no suction from floor brushes
Check the canister seal for dirt or gaps. This is normally where the vacuum leak is.
May 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Power Loss - Suction Loss
Hi
Its cutting out because its overheating.
Change the filters and check the base and the hose for blockages
Feb 14, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
294 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
