Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Stalling after one hour run time
LT 120 Runs for approx 1hr and begins to rev up & down then stalls. Can stave off stall for minute or two by choking. Eliminated fuel cap as the problem. Will start back up but rev and eventually smooth out but will stall again in 5-10 mins
    President:
  • 1,627 Answers
Sounds to me like you need to replace the ignition coil,they will go open when they get hot and when this happens the plugs will stop fireing.
Posted on Apr 25, 2010
Why it stalls at stops and low speeds
accord stalling on every stop. (1/2) - EricTheCarGuy ...
www.ericthecarguy.com/.../8.../46884-accord-stalling-on-every-stop
The car runs good but stalls every time i come to a stop. ... a stop then it diesagain.only on the stops does the idle drop very low to the point of stalling.what ... only when I start slowing down and come to a complete stop RPM's go down and the cardies. ... The popular Honda Civic and Accord vehicles share many powertrain ...
1998 Honda Accord loses rpm/ stalls coming to a stop ...
honda-tech.com/honda-accord.../1998-honda-accord-loses-rpm-stalls-co...
Jan 10, 2013 - I just bought a 1998 4 cyl 2.3 L Honda Accord two days ago. ... 1998Honda Accord loses rpm/ stalls coming to a stop. .... Is clockwise high idle or low idle? all in all i probable rotated counterclockwide 1.5 or 2 turns. maybe this ...
1999 Accord, 130k+, stalls when slowing to a stop - Honda Accord ...
www.hondaaccordforum.com > ... > General > General Tech Help
Mar 10, 2010 - My fiancee's '99 Accord EX Coupe 4-cylinder automatic, with 130,000+ miles, has recently (in .... No low RPM & feeling like it's GOING TO stall.
99 Honda Accord - Strange Stalling Issues! HELP!
https://www.2carpros.com/.../1999-honda-accord-99-strange-stalling-issu...
My 1999 Honda Accord is having sporadic stalling problems. I've noticed a pattern. Itstalls while going slow speeds and stop and go traffic, etc. The engine just ...
Stalling or Low Engine Idle Speed Due to Dirty ... - Repair
Jan 02, 2016 | 1999 Honda Accord
97 park ave ultra is hesitatating when I start using the gas as I start an incline mostly but sometimes just randomly an it's getting worse
Engine Stalling Due to Mass Air Flow/Crankshift Position ...
repairpal.com > Problems > Buick > Park Avenue
Buick Park Avenue Engine Stalling Due to Mass Air Flow/Crankshift Position Sensor Failure. This is a verified ... 1997 Buick Park Avenue- 3.8L V6160,000Visitor. Engine stalls ... car runs then stalls and won't start for thirty minutes. Upvote (36).
Buick stuttering Questions & Answers - Fixya
www.fixya.com > Forum > Tags > stuttering
94 Buick Park Avenue that stutters under a light load I have a 94 Buick Park Avenuethat ... Buick Century 97 runs rough and stutters when cold and gas applie Engine runs rough ... I have a 1994 buick lesabre it starts ok but stutters and stalls.
Oct 30, 2015 | Cars & Trucks
02 gmc sonoma 4.3 engine starts and runs great for 30 minutes and then stalls like its flooded, if it sets after stalling for 30 minutes and cools able to drive home before starting to stall again. After...
Smell of the oil,to see if the fuel injector(spider)is leaking into the crank case,if so,the intake will have to be removed to repair the problem,oh,and change the oil.
Jul 11, 2010 | 2002 GMC Sonoma Extended Cab
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
Stalling after about 15 - 20 minutes
Change your fuel filter first.
If the problem is still there your fuel pump is going bad.
Aug 11, 2009 | 1987 Ford F 150
RUNS GOOD STALLS AT DIFFERENT TIMES; ae. STALLS HOT OR COLD
when you removed the water pump, did you disturb the timing in anyway ???
Jun 21, 2009 | 1992 Oldsmobile Cutlass Ciera
YS 4500 Stalls out after running for 20 mins
I do believe they change plug(s) and air filter? There could be impurities and water in tank. Check for any loose electrical connections. Problem with valve clearance. Keep me informed.
Jun 13, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
1999 Alero stalling and trac off light coming on
does the rpm motor kick down? you may need to check your vacuum hoses, and also you may want to check your exaust, sounds wierd but that can cause the car to stall at times.as for the traction light, your hitting the brakes to hard. try slowing down a little slower while stopping, and keep distance for saftey.. if you can take it a little slower at lights and turns, without braking hard and it stops stalling.
May 20, 2009 | 1999 Oldsmobile Alero
STALLING PROBLEM TURNED INTO NO START 1990 MB 300 SL
hello,good day,first we are in fuel side,better to install a fuel gauge,to determine the right pressure, is not mention your fuel pump relay,this should also check,some occasion the power supply is missing,now if all is in order (fuel side) then your switching unit(transistor box) need tobe check,assuming your engine is 103 engine,ty
May 17, 2009 | 1987 Mercedes-Benz Mercedes Benz 190 Class
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
731 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
