Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Cannot detect cartridge
At Start was not printing black. Going through cleaning many times had no effect. At some point it asked to replace cartridges. I knew the black was low so I replaced it. Next it started asking to replace all cartridges. I did. Now it keep asking to reinstall magenta and sometimes cyan, "cannot detect cartridge" And it won't print at all.
Mix-it-up
  • 832 Answers
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Posted on Sep 17, 2007
tom19511
  • 1601 Answers
SOURCE: Epson R260 ink cartridge problem (yes, with the genuine Epson ink)
Try this:
http://er.epson.com:8001/start
Posted on Feb 20, 2008
  • 7 Answers
SOURCE: Brother MFC 5460CN No cartridge error
Third place I'm posting this today... This solution worked for me:
This is a simple fix. This printer uses a LIGHT SENSOR to detect if the cartridge is installed properly. Numerous things can allow extra light to enter... your solution is this:
Get electrical tape (duct tape may be too thick) and cover the rear sides of your cartridge; along with the recessed square shaped area that is directly in the center of your cartridge. Cut the tape so that you can cover this area without impeding the shape of the cartridge (so it can still be inserted and removed easily) I have used this solution to repair this exact problem on MFC-665CW when installing a continuous ink supply (in place of the original cartridges) You can actually just tape the internal sensor and close the front cover if you want to test it without any cartridge at all (though its not a good idea to print like that as I"m not sure if it will damage the unit) Those of you wishing to only buy Black ink can attempt this if you dont care about voiding the warranty or possibly breaking the unit... just cover the other slots with electric tape.
Posted on Feb 21, 2008
POCBM
  • 121 Answers
SOURCE: hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Posted on Apr 02, 2009
My printer will no longer print in black s520
if it is a new black ink cartridge and the printer still wont print black start by:
A: Simply making sure the settings are ok. To do this, go to file>print. When the printer box shows up. click properties.
From there, you will be able to see color settings. (ex. black, grayscale, full color.) Try switching to black or "use black cartridge only.
B. If "a" does not work for you, the print head which hold the ink cartridge is clogged or no longer working. Through the cannon window on the printer, try running a print head cleaning or any maintenance program.
If there's still no black, the print head has seen better days and needs replacing. Most of the time it is more effective to get a new printer.
May 22, 2011 | Canon Office Equipment & Supplies
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Kodak 5500 printer can't detect print head
open the cover and take out the printheads and clean the contact points. also clean the contact points on the printer.
reinstall it and see what it does,also try turning the printer off and on /
if this does not work you need a new printer /the printer hardware is bad for sure if you have already replaced the printhead and catridge .
if printer is in warranty ask for a replacement
Aug 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black Printhead needs cleaning - how do I get to it?
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Installed black ink but hp psc 750 keeps saying install colour and i only have black ink. Can you operate this printer without colour in.
Print cartridge
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
Aug 19, 2009 | HP PSC 750 All-In-One InkJet Printer
I just changed my black ink cartridge. Now, after
Print cartridge
Aug 18, 2009 | Office Equipment & Supplies
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Replaced Black Cartridge...will not function
hi hello i tell you try replace that cartridge of yours. if your still use it, not working.. that cartridge is damage..
Jun 16, 2009 | Lexmark X1150 All-In-One InkJet Printer
Ink cartridge assembly not going to correct posy to replace black
Remove the cartridge and put it back in. If still it doesn't work, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the black pattern or no black appears at all, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
