Question about HP Photosmart D5360 Printer
My computer says "Paper Size Error" and wont print my document, even though i have normal size paper in there that i always use, how do i fix this?
5 Suggested Answers
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Posted on Jan 26, 2008
  • 14 Answers
SOURCE: try printing from tray 2 using letter size paper
check the paper size in the printer driver settings.
this should also be set to letter.
Posted on Oct 29, 2009
SOURCE: even though when the paper size has been chosen correctly it ejet
MY HP DESKJET 1280 CANNOT PRINT PHOTOS ON A3 PHOTO CARD
Posted on Mar 25, 2010
seeker5211
  • 1089 Answers
SOURCE: "Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Posted on Jan 11, 2011
Cp305d paper size error
It may be a sensor problem When you reseat the tray it may not be actuating the paper size switches correctly. Check the paper tray and make sure that there aren't any missing or broken/bent tabs on it.
Mar 17, 2014 | Office Equipment & Supplies
I have a canon MF 8350 cdn and when i try to print certain documents such as pdfs or excel sheets the printer prints out a couple pages then gives the error "check paper size" even though it is...
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
Jun 01, 2011 | Canon MF8350Cdn AllInOne Laser Printer
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Can't print proper legal size documents
please you aply the comand control p and you go the property select
and ok. you so the paper select and ok and you so the paper size
in select legal is ok and ok
and aply print legal size print ok
Sep 15, 2009 | HP LaserJet 1018 Printer
My canon mf8100 series prints once, then beeps and
set the paper size to A4 in ur computer and in ur printer
Aug 29, 2009 | Canon MF8180C Color Laser MFC Printer
Hi I have a Konica Minolta 2490MF and when I try to print a document/s it will print the first page only then comes up with an error 'incorrect paper size (1LT)' the paper size is correct (A4) and the...
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Paper Size Error
Hi there check that the printer properties have not been changed.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on printer icon
  • Select Printing preferences
  • Check that the paper size matches that you have got in the tray
  • OK and exit and test
If the above doesn't work try the following
  • Open MS Word
  • Open the document that you are having problems with
  • Click File
  • Select Page Setup
  • Check that Paper Size is correct
  • OK close and test.
This is normally a driver issue as the paper tray on the printer doesn't know what size paper is in it until you tell it from the driver.
Hope this works for you
Thanks J
Dec 27, 2007 | HP DeskJet 5650 InkJet Printer
HP Photosmart D5360 Printer Logo
13 people viewed this question
Seeker5211
Seeker5211
