Question about Asko 1595 Dishwasher
Control Board bad
I have a Asko 1595 with a blown main control board. I work in electronics and may be able to fix it. (A new one is more than the cost of a new lower priced dishwasher.) Is there anyplace I can get a schematic diagram for it and/or a parts listing for the board compotents?(in particular a certain transistor.)
    Sergeant:
  • 351 Answers
Most of the time there is a schematic behind the kick plate or the door skin but it wont tell you the value or the resistors.but theres normally another cause for the board to blow.is the rinse aid leaking into the door skin,or wires starting to break in the door.the boards are normally sold complete.I work for asko and find the boards dont normally fail by themselves.hopt this helps.
Posted on Mar 23, 2008
Maytag dryer 3000 series MEDE300VW1 7 years old dryer will not start F01 code comes up many people say replace the electronic control board,how do I troubleshoot on which one is bad?
code f-01 refers to condition main electronic control board failure
you fix if you want to diy is to buy another board from the service agent spares and replace the existing board
however while that error code is coming up, you would ba advised to get in a technician to check out the machine to see if there is not another problem causing he board failure
Jan 09, 2017 | Maytag Washing Machines
WHIRLPOOL SID BY SIDE FRIDGE MODEL GD5RHAXNT00 LIGHT HAS GONE OUT IN REFRIGERATOR AND TEMP GUAGE IS NOT SHOWING A READING
What youre experiencing is a common main control board failure.
The main control board for this model is no longer produced. But, don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. W10135090 Whirlpool ELECTRONIC CONTROL BOARD MAIN CIRCUIT BOARD
May 26, 2014 | Kenmore 57029 Side by Side Refrigerator
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
F06 error code
F6 error indicate a Motor Speed error code. It is likely attributed to either a broken or slipped drive belt, defective Drive Motor, defective Motor Control Unit (MCU), or the interconnecting wiring between the two.
Could be a loose connection in the harnesses, dad Motor, bad motor control board, bad main control board. It's most likely a bad motor control board.
Here is the one parts for your model:
- Electronic control assembly
- Motor Control Unit
- Drive Motor
Also, remember that RepairClinic.com will refund all parts within 30 days that you purchase from them if they don't fix the problem, EVEN electronic parts.
Hope this helps.
Sep 22, 2011 | Kenmore HE2 Plus Front Load Washer
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Apr 04, 2011 | Asko W6021 Front Load Washer
Asko dishwasher starts and immediatly stops
Hi mike, thanks for the clarification. Having this info, I am not sure this model is as the post indicates - "1595". Is it possibly a 1473 or 1474 model with a power button by the door handle ? If so, that is the most common problem with that style Asko. The contacts inside the button make momentary contact & then stop which requires replacing tge switch. Let me know if it is indeed one of these models or confirm what model number it is ok ? Thanks, Macmarkus
Apr 22, 2010 | Asko 1595 Dishwasher
I have a 2004 whirlpool gold model #gd5rha. When
you need a new control board,this is very common,especially if the bulbs on thr refrige side blow out,this creates a surge and ruins the control board $85.00 w/shipping at appliance parts pros or 1-877-477-7278
Oct 06, 2009 | Whirlpool Refrigerators
AKAI Plasma TV PDP5016H
See I cant cross that part number and I have all the boards sitting in front of me. That number is the akai part number, but not the actual number of the board. There are 2 boards that they call main in the service manual, the main control board which actually drives the panal, and the "main video board" which handels the video inputs and on screen displays.
PCB failure analysis
1. MAIN CONTROL : a. Abnormal noise on screen. b. No picture.
2. MAIN (video): a. Lacking color, Bad color scale.
b. No voice.
c. No picture but with signals output, OSD
and back light.
If you can determine which of the 2 boards is the problem, I can sell you a new replacement for $125 shipped.
Basicall....Control board is no picture at all.
Main board is no picture, but on screen displays work.
Aug 16, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Asko 1895
First make sure your door switch is making proper contact.If not replace it. If it checks out ok than your main control board is bad.
May 21, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Dishwashers Logo
319 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
