Question about Canon i350 InkJet Printer
Hi ;the printer doesn t print black;only color .I ve just replaced both cartridges
SOURCE: Black 3ek cartridge not printing
I had the same problem before with 3e black ink. It simply does not print too, so what I did if i get to print black and white i will set the characters into dark gray! it looks like draft printing but the things is it can be printed.. I tried to do every instructions available but to fail. I almost dump it till I decided to set it aside for a while. After a week I tried using it again, and it functions well. I guess the printer just want to say, "HEY BUDDY, GIVE ME A LITTLE BREAK!"
Posted on May 15, 2008
SOURCE: Its not printing in black
I had the same problem. Too early to know whether this will help in the long run, but I can print in black if I select manual instead of automatic. The print quality is fine which would suggest there is nothing wrong with the head.
Posted on Jun 17, 2008
uten
  • 162 Answers
SOURCE: new cartridge won't print
re-seat the black cartidge, do head cleaning, get a windows test page (go to printers and faxes then right click on the printer icon and choose properties, click the print test page button).
replacing ink cart is the next step or service.
Posted on Nov 26, 2008
pagebor
  • 2785 Answers
SOURCE: Printer Canon Pixma MP750 won't let me use just black ink
you cant print without color cartridge
Posted on Mar 14, 2009
  • 43 Answers
SOURCE: Printer will not print in black and white only.
The printer will not print unless you change the specific cartridge that is empty, so change the cartridge and install a full new one. then you should be ok
Posted on Sep 03, 2009
My desk jet 3320 printer do not print black
Are you sure there is enough level on the black ink cartridge.. if does try to do "print head clean up" if doesn't fix the problem consider to replace the black ink cartridge
Aug 31, 2012 | HP DeskJet 3320 InkJet Printer
Epson Workforce 600 not recognizing black toner
I had the same problem and was told by the store that sold it to me that some printer manufacturers do this on purpose as they make their most money on the ink they sell not the printer. I got rid of mine and purchased an ink jet black only printer as this is all I need anyway. A lot cheaper to use.
Jun 12, 2017 | Office Equipment & Supplies
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
I have hplaserjet pc1515n color printer but when iam giving it print it give black and white not in color.
I have a similar HP Color Printer on my desk. I think that your printer is set to PRINT IN GRAY SCALE
- Go to Control Panel
- Open 'Printer & Faxes'
- Right Click the Printer and choose 'Printing Preferences
- Go to Color and un-check 'Print in Gray scale as shown below: -
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 30, 2011 | HP LaserJet CP1515n Printer
Installing only one printer cartridge
suggest you install a color cartridge and set up the printer for color. When the color cartridge runs out of ink, you should be able to continue printing in black only.
Mar 19, 2010 | HP PSC 750 All-In-One InkJet Printer
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Canon i350 InkJet Printer Logo
13 people viewed this question
old marine
old marine
