Question about Lightning Audio LA1.300.2 Car Audio Amplifier
POWER JUST BOUGHT AMP AND HOOKED IT UP AND IT WONT POWER UP WHAT DO YOU THINK THE PROBLEM IS
  • 807 Answers
Have you connected the remote wire from the stereo to the amp? assuming it has one.
If the stereo has not got a remote wire you can link it from the positive 12 volt on the amp to the remote connection on the amp, usually it's in between the ground connector and the 12volt.
Posted on Mar 23, 2008
SOURCE:
Crossfire vr2000d wont stop cutting out
Bad ground, possibility of some wires touching
Oct 25, 2017 | Crossfire VR2000D Car Audio Amplifier
I have an Dual brand 300 watt amplifier that I just bought and I hooked everything up right (battery---power, ground----sanded metal, bypassed remote with toggle switch remote-----+terminal on switch...
Is your toggle hooked to ground? Hook your toggle switch to the battery and then the other end of that toggle the remote input on the amp.
Aug 15, 2010 | Car Audio & Video
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
I have a kenwood kdc 233 cd player in my car but the remote wire aint working because i tried hooking up an amp i pit a light power tester on the remote wire but dont work and i dont think the input plugs...
as far as the remote wire a keyed power wire from under dash can be used its the same thing.if the remote wire is working it wont turn on your amp so are you sure thats not why your rcas dont work or have u hooked power to the remote on the amp.
Nov 09, 2009 | Car Audio & Video
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
No power to subs
I think the blue wire is a standby "on" to be hooked to separate or system switch. Without knowing how you have system wired, I can' offer much. A bit of caution; having a thousand watt amp hooked to 6x9 dooms their fate
May 06, 2008 | Legacy Audio Blue Diamond LA1880 Car Audio...
Amp cd proble3m
i'm not entirely sure but i think that your only supposed to have the blue remote wire hooked up. but like i said i'm not sure. i hooked my amp up and somehow my remote wire shorted and fried my ignition switch so don't hold me to it, but maybe look into it. I think that you might have a constand power hooked up to a switched power cable for your amp so haveing the constant power to your amp, asied from your 12v at the battery, your amp might not even know when your car is on or off. hope this helps sorry for the open ender
Mar 14, 2008 | Pioneer DEH-1600 CD Player
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
Lightning Audio LA1.300.2 Car Audio Amplifier Logo
70 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Mark Skinner
Sheldon Dedek
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
