Question about Lands Phones
I cannot get a dial tone. i have replaced handset batteries and charged for 24 hrs to no avail. are there any batteries in cradle to change? product is two and half yrs old? it is an sse 15 model with two handsets
  • tdbeath1 Apr 22, 2010
    i have changrd phone lead and only get a roaring wind sound. if this is s network problem why is internet working ok? is it possible that something needs fixing on the base and if so what? thanks for your help. Dawn
  • tdbeath1 Apr 23, 2010
    tku i have been onto service provider and it is a telstra problem. many tks yr help. dawn
  • 821 Answers
HELLO,THIS IS ACTUALLY A WIRING PROBLEM OR YOU CHECK THE CORD THAT GOES DIRECTLY INTO THE PHONE TO SEE IF IT'S PROPERLY PLUGGED,AND IN MOST CASES THIS COULD ALSO BE CAUSED BY POOR SIGNAL OR BAD NETWORK SERVICE FROM YOUR SERVICE PROVIDER.SO I WILL ALSO ADVICE YOU GET IN CONTACT WITH THEM TO SEE IF THEY ARE HAVING NETWORK PROBLEM.
WISH YOU GOOD LUCK,
TAKE CARE.
Posted on Apr 22, 2010
  • Hammid Disu Apr 22, 2010
    HELLO,
    1. If you have a second phone line in the house check to see if that works, if not go to step 2.
    2. Step 2
      If
      you have a cell phone try calling yourself, and see if the phone rings
      or if you get a busy signal, or an operator message that can confirm if
      the phone company disconnected your phone service. If you get a message
      your phone has been disconnected, call your phone company.
    3. Step 3
      Unplug your phones for at least 15 minutes, all phones in your house and all lines just from the wall jack and power from the cordless phones.
    4. Step 4
      After
      15 minutes plug your phones back in the jack one at a time, pick it up
      and see if there is dial tone. If not the phone might be defective,
      check the other phones.
    5. if the problem persist i will advice you contact your phones companies line
    take care.
Buttons don't make any sound but can hear dial tone, speaker phone doesn't work, phone dies fairly quickly - would this all be caused by bad battery and what is the life of battery in a Panasonic cordless...
First off, try changeing from tone dial to pulse dial and try calling out. If that does'nt work, touch bad is probly bad. As far as the speaker phone it does not work off battery's it works from the main base which is powered from the A/C. And for the battery life, when you have a cordless phone you have to build the life to the battery, what I mean is : first time you charge it for 12-14 hours, after that use the phone and do not put it back into cradle, the battery will hold a charge for 8 hrs, if you use it for 30 mins and put back on cradle untill next use, use another 30 min and continue doing this the battery will build its life to 30 min and always die after 30 min, try to get into leaveing off cradle all day and charge while you sleep and keep off cradle all day.
Nov 07, 2013 | Panasonic Lands Phones
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
Unable to charge. it still says charging
You should return the product. This is relatively common, it needs a new battery. The battery will not take a charge. Here's the thing, batteries for cordless phones are a fortune. You should either return it or if you can't probably just buy a whole knew one.
EJ
Jul 02, 2010 | AT&T E5640 Phone
I am unable to get a dial tone on my new uniden cordless phone ?
Did you insert the batteries properly and register the handsets? You must give them a good charge and put both handsets into the main cradle before they will work at least ten seconds, that will register the handsets to that main cradle. Good Luck...
Feb 14, 2009 | Uniden Cordless Phone
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Jul 19, 2008 | GE 25942GE2 Cordless Phone System
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
20 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
