Question about Akai LCT2662 Television
Our power indicator is blinking and the television is not coming on. This happened once before, is this a continuing problem? How much should it cost to have the part replaced? We paid $150 the first time and this time they want $450. We are in Costa Rica and I think we are totally being ripped off - want to have a reality check.
  • jancristo Apr 22, 2010
    Taran, thanks for your prompt reply. I'm shocked at what sounds like a relatively simple repair. I'll try and find someone who can do this for a reasonable rate, and get back to you if there are more problems. You are a great guy! Thanks again.
    Thanks Taran! I am so happy that you responded so quickly and gave so much detail. You are great!
  • 10,515 Answers
This Model is Popular for the Power Supply Problems.According to me it is a power supply problem which is quite common part as far as failures are concerned. IF you TV is under warranty then you can get it checked and replace for free probably.
This is basically due to lack of sufficient power. This is basically due to capacitor failures or cold solder problems. You probably have lose solders or broken solders due to the move.
You need to Open the TV. Make sure it would be Unplugged. You need to Take all the Precautions. Locate the Power Supply Board. Remove the Connectors and Pull out the Board. Once you Pull out the Board, with the Help of Magnifying Glass, locate Cold Solder Joint. If Everything is OK, then you would Locate Bulged / Leaked / Swelled Caps. They would have Ammonia kind of Odor. You need to De-Solder them. You could take the same to Radio Shack / Fry's / Order Online. Once you get the New Caps, Solder them and it is all set.You also need to Check Fuses around that.
If the Problem Still Persists, get back to me so that we would Troubleshoot other Components.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 22, 2010
Standby button flashes tv not coming on trying to locate the reset button
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Aug 10, 2011 | Sony KP-41T65 41" Rear Projection...
My LCD Sony KDF-60WF655 Powr/Standby light started to blink and automatically cut off after 10-15 minutes of being on -- the cooling fan comes on and then it powers back on. Now it is happening about...
Jul 28, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
STANDBY LIGHT BLINKS ONCE AND STAYS ON CAN HEAR A CLICKING WHEN PLUGGED IN NO PIC NO SOUND HELP PLEASE
Jul 18, 2011 | Sony KP-53V80 53" Rear Projection...
My sony trinitron won't come on. I have a blinking light, it blinks 4 times fast. can you help me
Jul 17, 2011 | Sony Televison & Video
I have a sony 57 inch hdtv that I purchase in 2005. The tv has performed flawlessly until today. My Timer/Standby red light is on and is blinking and the i.link standby light is currently on and is a...
Jul 16, 2011 | Sony Televison & Video
When i turn on my tv the little red light blinks. THen the sound comes on but no picture. After a couple of seconds the red light starts blinking again and the standby light comes on and then nothing.
Jul 16, 2011 | Sony KP-51HW40 51" Rear Projection...
My kids were watching the tv when it shut off. When I got home I turned it on and green light flashed about 100 100 times now the red light flashes continuous. Tv still not coming on.
Jul 07, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Red standby button comes on after power comes on. It blinks 13 times, pauses few seconds, then 13 more blinks
May 25, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv shuts off,standby light blinks 5 times repeatedly until tv comes backon
Mar 14, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Akai LCT2662 Television Logo
43 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
