Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
How do I get old motor off pump to install my new motor?
I've got a hayward pump serial # 680823 with a bad motor 1hp. I now have purchased a new motor 1hp 1081 emerson. HOW DO i gET pump housing apart to install new motor?
  • 78 Answers
The front of the wet end must be removed to access the impeller. Then remove the rear electrical covering to expose the rear end of the motor shaft. Look closely at the shaft. It has two flat sides. A 12mm open face wrench will fit onto the shaft. Lock the shaft in place with the wrench and unscrew the impeller. The rear housing behind the impeller pops off to reveal four 9/16 bolts. Remove them and the motor is free. Reverse the process with the new motor.
Posted on Apr 22, 2010
I HAVE A BAD 1HP SUPER PUMP MOTOR CAN I CHANGE IT OUT TO A 1.5 HP SUPER PUMP MOTOR
yes it should be a direct swap ask the place you buy the new one from they will know for sure
Jun 25, 2014 | Hayward 1hp Super Pump In Ground
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
I presently have a Hayward EC 60 (yes 60) pool filter and a 1 horse power motor.. It works well but it does not support the new Pool Vac cleaning robot I purchased. It supported my old Pool Vac, but not...
if you buy an adaptor,should be a 1 1/2" dia hole,in the bottom of the skimmer, put it in the skimmer hole,put your vac line on that, turn the valve to it's on full skimmer, it will work,
thats a nice filter,pool guys will sell you anything!
esp at this time of year!
buy the minumum!
Sep 13, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Just purchased a new super pump 1hp, but it is
Can you be more descriptive? My guesses are that the motor is wired wrong, the motor is defective, There is a leak in the supply line or the pump and air is getting into the pump, causing the pump to cavitate.
Jun 02, 2010 | Hayward 1HP Super Pump II Inground Pool...
Hayward 1hp super pump stops working
Your motor has a thermal protection switch in it the reacts to an overheating condition. Once the motor cools enough it will turn back on. You may be able to have the motor rebuilt for about half the cost of new if it is not damaged to severely. Take it to a local electric motor repair shop for service. If it is damaged beyond repair, you can shop around for a new one. If you would like a quote, contact us at www.arrowpools.net with your pump model number and we can quote it.
Jul 12, 2009 | Hayward Pool Products HAYWARD 1 HP 2 SPEED...
My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
Jul 03, 2009 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
609 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
