Question about Dyson Ball DC24 Bagless Upright Vacuum
The handle attachment will not pull out anymore.
The handle attachment will not pull out no matter what I do.
    Scholar:
  • 48 Answers
Ensure the handle lock is disengaged. This is an often overlooked problem.
Posted on Apr 23, 2010
Spray trigger stuck?
Hi there! If the spray trigger is stuck try removing and replacing the handle. Remove the two screws that attach the handle. Slide the handle off. Inspect the two rods inside of the handle for damages. Make sure both rods are pulled down. Replace handle and two screws. If the spray trigger is still stuck or if the rods were damaged in any way a replacement handle may be needed. If so I have included a link where you may purchase a replacement handle. Search Results Good luck!
Aug 07, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin anymore
There is a spring that goes on an arm, #32 in the picture. It actuates the turbine so the brushes will turn when the handle is tilted back, and stopped when upright. This might be where that spring goes. You may have to take the top cover off to put in on. After you get it on, and the brushes still don't turn, look up in the square hole where the shaft on the brush block goes into, turn the unit on and see if it is turning, if not then the turbine either needs to be taken apart and cleaned or replaced. The turbine is what drives the brushes.
Mar 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Handle came off of the container that the dirty water goes into
If it 'came' off it's just a matter of re-attaching it. You weren't very clear in your post. If it 'broke' off, then it's best to order a new top from your dealer. If the unit was something you just picked up at a yard sale. See if you can find another.
Jul 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How can I fix my Hoover spin scrub 50 solution trigger? It is not working.
Hey there! Sounds like you have no tension in your trigger. This could mean a problem with the trigger spring or control rod in the handle. Try reassembling the handle. Remove the two handle screws and slide the handle up and off. Inspect the control rods for damages. They should be the same length. Make sure they are pulled down as well. Reassemble the handle. If the trigger still has no tension but the cleaner dispenses from the hose, a replacement handle may be needed. To replace the handle, follow the link below.
Search Results
Hope this was helpful!
Jun 11, 2014 | Hoover SteamVac Spinscrub 50 Carpet...
The handle pull comes completely out when you pull the handle to use
Hi! There is a handle screw that attaches the handle to the vacuum that prevents the handle from coming out. I have included a link where you may go to purchase the handle screw if your vacuum is missing it. Hope this helps!
Search
May 24, 2014 | Dirt Devil Easy Lite Quick Vacuum
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
Removing portable cleaner handle
To remove the long handle with cord attached, there is a press button at the bottom near the top of the vacuum body.. Mine is covered with plastic with press written on it.. You just press the button and pull the handle off.. takes a bit of force to pull the handle out...
Lee in Australia
Sep 07, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I'm sorry to hear you're having difficulty with your DC24. The wand should detach easily from the machine when the red release catch is pressed. If it seems to be jammed in place, I'd encourage you to give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US) - one of our advisors will be happy to run through some troubleshooting to make sure everything is correct with your machine.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
I disassembled the handle to attempt to remover the slip in upper half of handle. (did not figure out how to do tht). Now on re-assembling the handle, I cannot figure how the trigger is held secure to...
HI.These are the steps that may be helpful since you haven't describe the brand of your unit.Open the storage door at the front of the vacuum.Redmove the powered hand tool. Set it aside.Unsnap and remov any attachmets at the attachment storage area.Unclip and remove the wands from the vacuum and set aside.Pull the end of the hose from the hosed tube rack.Twist the other end of the hose from the dirt duck tube.Remove the hose.Unscrew the back of the handle.If you can't remove ,it is held tightly with nbuts located at the back of the compartment bag.Pull the handle carefully from the vacuum.If it has a non built cord wrap,slidethe wrap straight up from the handle too detach it before removing the handle.Once done assemble back.Thank you for choosing fiXYA.
Jul 31, 2011 | Vacuums
Dyson Ball DC24 Bagless Upright Vacuum Logo
324 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
