Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Cannon mf4150 toner not set will not go off even with a new cartridge it is installed properly as always how do you get it to reset
SOURCE: TONER CARTRIDGE
Follow these steps (per Samsung Support) to reset cartirdge error:
Press Menu, #, 1934
Screen will read: Ready, Tech Mode
Press Menu until you see Data Setup
Arrow through till you see New Cartridge, enter yes and hit OK or enter
Now re-enter Menu, #, 1934 to get back to Regular Mode
Toner Empty message should be gone!
Good Luck!
Posted on Aug 20, 2008
SOURCE: toner
I had the same problem with this printer. And I think I got the problem solved by removing the all paper from the paper tray, and re-inserting the toner cartridge. I think it is the problem with incorrect error message from Canon's printer. It is problem of paper being fed into the printer mechanism slightly.
Posted on Sep 12, 2008
yooperbud
  • 8637 Answers
SOURCE: cannot align ink cartridges in my cannon mp160 printer
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
xptareq2000
  • 1447 Answers
SOURCE: how to reset samsung scx 4300 printer cartridge
you can not reset this chip change it you must be buy a new one cartridge
Posted on Nov 04, 2009
pineworks
  • 4041 Answers
SOURCE: My Oki B2200 is repeatedly showing Toner is empty.
Hi there
I not know your printer but I can say this that after refilling it your chip will still thing it emty so some where on the printer Menu there is a way to reset the it back to 0 so it starts like new again.
Sorry cant be any more use to you than this, try looking up the net or the manual to how to reset.
All the best : Pineworks
Posted on May 10, 2010
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
"Toner not set" persists, even though new
Hey!This happens a lot!Take out all of the paper,Open the cover,take out toner,put it back and add paper!!If this does not work then the toner sensor might be faulty!Good Luck!!
Nov 03, 2010 | Canon imageCLASS® MF4150 All-In-One Laser...
Phaser 4510 replace toner message won't print until new toner installed - new toner installed and still has the replace toner message
  • This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
  • Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered
  • Make sure you don´t have any stickers on the toner box.
  • If you sure all paper and stickers are out then reset the nvm values from the device in order to reset the printer information.
Aug 27, 2010 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I am getting an error message that says "toner is not set, insert toner." I purchased a brand new cartridge, have taken it out a bunch of times and tried resetting it, nothing works. I've had the printer...
I had a similar problem on a Lexmark T520. Some of the off brand generic (and even a few brand name) toner cartridges have slight changes in design that make them miss, or nearly miss the sensor that indicates they're installed. this is usually a metal or plastic actuator on the top of the front panel door.
You can try putting pressure on the printer at different points on the cover. If this wakes up the printer you can either tape paper on the cartridge to make it the right shape to hit the sensor, or get a cartridge from a different manufacturer.
Nov 13, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf4150 "Toner not set" Error
My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION. Remove the paper, then remove and replace the toner cartridge. Now put the paper back in, and you are ready to go. Our IT man rocks!
Dec 11, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
42 people viewed this question
old marine
old marine
