Question about Motorola Mobility CLIQ Cell Phone
My cliq says no sd card detected wen there is a sd card. Why can't the phone detect it?
    Master:
  • 697 Answers
Does your SD card have more capacity than the unit can handle? If it can only use up to 8GB and you install a 16GB card, it may not be recognized.
Posted on May 06, 2012
  • 58 Answers
There may be some files corrupted in your sd card...you should formate your card and then try.. i hope this will solve your problem..
Posted on Apr 22, 2010
How do I get my files off of an sd card(for a phone) that neither a phone or computer can detect?
hi this might help, ime not sure but try it, take card out of phone and put it in sd slot on your computer if it has one, if it dose not read the card, then go into windows explorer then computer and see if it is there, if it is then right click on it then press properties this will tell you if the card has anything on it, if it has then press it to bring up the info on the card, pictures and music and all data, hope this helps you...
Dec 18, 2014 | SanDisk 16gb Micro Sd Hc Microsd Memory...
My phone doesnt detect its memory card but when i connect it to pc ,, my pc detects memory card but my mobile does not???? Phone: videocon V1422
The problem is, that you type of phone can only handle a maximum of 2 gigs.
When you connect it to your PC it detects it, because the PC uses them (phone and sd), like two separate drives, and that's because when there is SD -> Phone -> USB cable -> PC, the uses the as a simple "cable".
So unfortunately you will have to buy a 2 gigs SD.
Dec 29, 2010 | SanDisk 4GB microSDHC Memory Card
How do i put music at my motorola cliq
You have a SD card, put it in the phone, connect it to the comp with the USB & when the SD card pops up, scroll down to music. & just drag your music into there
Feb 20, 2010 | Motorola Mobility CLIQ Cell Phone
When i try to download music from my laptop to the cliq it says the sd card is busy
1.) make sure the sd card is mounted after you plug in the USB cable. (pull down top bar and click on the USB notifier...)
2.) Open a window on the laptop that has your music.
3.) Open a window on the laptop that shows your cliq's sd card.
4.) Drag and drop the music files to the folder you want on the sd card
5.) when you are done copying, drag down the top bar again, but this time choose "turn off"... and you are good to go
Jan 12, 2010 | Motorola Mobility CLIQ Cell Phone
How do I unlock my sd card on my moto cliq
RE: Unlock My SD Card
you need to unlock the phone and not the sd card. google how to unlock that phone model or visit this site to unlock your inspire .it is easy
For more information: http://www.techyv.com/questions/how-unlock-my-sd-card
Dec 30, 2009 | Motorola Mobility CLIQ Cell Phone
How do i delete pic from my sd card on morotola right form phone
Accessing files on a memory card using the phone
To access files on a memory card using the phone, perform the following steps: 1. At the Home screen, tap the Applications tab. 2. Tap Quickoffice. 3. Tap Memory card. 4. Tap to navigate folders and files.
Nov 17, 2009 | Motorola Mobility CLIQ Cell Phone
How to remove sd card from motorola cliq
First, turn off your phone.
Once you get the battery cover off, you will see the SD CARD, there is a black fold down piece of plastic in front of the sd card, use something thin like your fingernail or a flat-head screwdriver to GENTLY lift it up, once the fold has been lifted you can now slide out your sd card...
Oct 23, 2009 | Motorola Mobility CLIQ Cell Phone
Memory card not detected
i had the same problem.. on your pc put a little file any file on the memory card. after eject and install in your phone, power up and it should detect it.
Jun 05, 2008 | HTC P3300 Smartphone
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Motorola Mobility CLIQ Cell Phone Logo
292 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
