Question about Jensen SC-570 Remote Control
I need the code for sharp tv please
Necesito el código para tv aguda por favor
  • 666 Answers
Configuring codes:
  1. Turn on the component that you want to set up. In the code listing find the 4-digit code numbers for your component brand.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
    The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over.
Code Readback:
  1. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  2. Release the component key.
  3. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  4. Press the "enter" key.
  5. Count the number of times the green light blinks. There will be four numbers, separated by a two second pause. The red light will tum off after the remote is finished reading numbers back. Make sure you write the code number below for future use!
Multi-Component Power On/Off:
    The Jensen remote has the ability to turn On/Off multiple components at once. When you perform the following steps, you can turn On/Off the TV, VCR, Satellite, Cable Box and Audio Receiver.
  1. Press the "action" key.
  2. Press the "power" key. Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
    When you press the volume keys on the remote they will control the volume on your TV. If you have a home theater system and want the volume keys to control your receiver only, you may set your volume priority to the receiver.
  1. Hold the "RCVR" key down until the green indicator light comes on. The green light should come on after about 3 seconds.
  2. Press "RCVR" key.
  3. Press "Vol+" key. To disable the volume priority you have to set and return to the default.
    To change back to TV priority:
  3. Press "Vol-" key. The volume priority will now default to the TV volume.
hope this helps
Robb
Posted on Apr 22, 2010
Tengo un control remoto universal Polar 9045699 y perdi la hoja de codigos y tengo un televisor LG. Alguien que me ayude con los codigos para Tv LG Flatron. Gracias de Antemano.
hola perdi el catalogo de mi control universal polar 9074996 y no tengo ni idea cuales seran los codigos, serian tan amables en ayudarme por favor
Jul 30, 2013 | Televison & Video
Necesito desbloquear mi nokia 2690
Hola, se puede desbloquear el m?vil por los c?digos de desbloqueo .. la forma m?s segura y mejor de desbloqueo es por los c?digos de desbloqueo y mi petici?n personal es que no van para el software de desbloqueo, porque a veces el software puede corromperse y que tus datos se perder?n debido a que, es mi mala experiencia, as? que fui para el desbloqueo de los c?digos de mobileunlocksolutions y unlocked.you tambi?n puede intentar, pero al ver que si su pa?s y el proveedor est? en la lista .. porque para algunos servicios s?lo est?n disponibles los c?digos .. ver con que y si el proveedor de su pa?s est? en la lista a continuaci?n, obtener los c?digos y desbloquear el m?vil ..
Oct 03, 2011 | Nokia 2690 Cell Phone
Como desbloquear codigo de seguridad motorola Q9 IMEI 358305010095173
ur defalt tel?fonos c?digos es 12345 o 00000 u puede utilizar
Predeterminado del usuario de 4 d?gitos del c?digo: 1234 ? 0000
Por defecto 6 d?gitos de seguridad: 123456 o 000000
Por defecto 6 d?gitos de seguridad: 000999 o 1122
Escriba * # 06 # en la pantalla del m?vil para saber el IMEI de su m?vil no.
enviar el IMEI no a m?, y yo le contestaremos con el desbloqueo de c?digo.
SI no Problema resuelto lo tanto
Por favor, instalar nuevo software en el problema del tel?fono se resolver?n
O:
Si por problemas de bacalao y puk pin As? que por favor
Mejor soluci?n: ir a la Oficina de Servicio y Sim y obtener el c?digo PUK y c?digo PIN de la Oficina oprator
Introduzca el c?digo PUK y el S?
Introduzca el c?digo pin y el S?
As? Puk c?digo abierto y el problema se resolver? r?pidamente
Bueno, si est?n vinculados a una red en particular todo lo que tienes que hacer es desbloquear el tel?fono para el uso que cualquier otra red GSM. Usted puede conseguir el c?digo de desbloqueo a trav?s de Internet. Dar su n?mero de IMEI y obtener el c?digo de desbloqueo de m?viles ur ........ ... .. Usted tambi?n consigue a trav?s de Internet .......... voy a sugerir el sitio web de Unlock-Zone.com que se haciendo un buen servicio ..... usted puede acercarse a este sitio web.
Aug 20, 2011 | Motorola Mobility Q9 Cell Phone
Me podrian dar el codigo de seguridad del nokia 1661-2 IMEI: 352676/04/285835/8
O:
Jul 26, 2011 | Nokia 1661 Cell Phone
I loss my motorola e6 security code so please help me to unlock my phone
O:
Jul 26, 2011 | Motorola Mobility ROKR E6 Smartphone
My mobile model nokia 1208. i forget my security code. pls help me.. serial no, 354867024045688
O:
Jul 26, 2011 | Cell Phones
Nesesito codigo para que mi control funcione para television SHARP y como ingresarlo
Hola mi nombre es Mayra Diaz con DISH Network. Sera un placer ayudarle y proveerle la informaci?n que necesita para programar un control de DISH Network a su televisor Sharp. Hay ciertos c?digos que se pueden integrar al control que le permiten funcionar con la televisor, unos de los c?digos serian los siguientes: 628, 739, 741, 608, y el 654. El procesamiento a integrarlos es el siguiente: Presione el bot?n de T.V localizado en la parte de arriba del control hasta que se prendan los dem?s en rojo una vez esto suceda ingrese uno de los c?digos seguido por el signo de numero por ejemplo (#700). El bot?n de T.V deber? iluminarse 3 veces en rojo si el c?digo es compatible. Despu?s de esto puede intentar usar el control con su T.V. Espero esto le sirva de ayuda si tiene preguntas adicionales o necesita ayuda puede contactarme directa mente a mi correo electr?nico
Apr 19, 2011 | DISH Network IR Remote Control
Nesesito programar mi control a una televicion sharp
Hola mi nombre es Mayra Diaz con DISH Network. Con mucho gusto le puedo ayudar a programar su control a su televisor Sharp. El primer paso seria verificar que tenga bater?as nuevas el control. Vamos a presionar el bot?n de TV asta q las cuatro luces est?n encendidas esta localizado a un lado de SAT es un bot?n blanco. Despu?s que las cuatro luces est?n encendidas presiona estos siguientes c?digos 628, 605, 607, 655, 658, 669, 670. despu?s de presionar el primer c?digo presiono el cigno de numero localizado abajo del 9. Cada uno de los c?digos se tiene que tratar uno ala vez. Finalmente presiona volumen para verificar que funcione, no olvid? presionar SAT para poder seguir cambiando de canales. Si tiene alguna otra pregunta por favor escribanos.
Sep 30, 2010 | DISH Network IR Remote Control
El codigo del control remoto de una tv mitsui
el control remoto del digitalizador motorola no trae codigo de acceso a la tv mitsui, cual sería el código de acceso; hablé a Megacable y no tienen registrada la marca de la tv así que no pudieron darme el codigo de acceso y me recomendaron que indaagara en internet
Dec 19, 2009 | Televison & Video
Jensen SC-570 Remote Control Logo
183 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
