Question about Maytag MSD2756GES Side by Side Refrigerator
Not defrosting. Thanks for the suggestion. Where is the board?
    President:
  • Maytag Master
  • 2,651 Answers
Adaptive defrost board, is hte board in question im assuming. ite located in top right hand corner of refrig section, under the shrouding. there are finger holes in the back of hte top controll panel to reomove the plastic housing(it kinda snaos down and pulls out. from there their are 2 1/4 screws holding hte control up and alsoa philips screw behind each of hte light bulbs. hte control will then drop far enough to gain acess to the board. its a little tricky to prop tha panel , but it will come
Posted on Mar 23, 2008
  • 3 Answers
You have to replace the thermostat defroster assembly Its behind the panel at rear of freezer and runs down and under condenser coils. Part cost $42 and plugs in its easy to replace It creates heat which keeps the coils free of ice and also keeps drain from freezing.
Posted on Oct 09, 2008
GE refrigerator model GTS18DC. Freezer is as cold as it should be. The refrigerator isn't getting cold. What could this be? Thanks!
freezer blows cold air to fridge, sometimes freezer freezes at back and blocks holes for outlet to fridge, defrost and restart, or take back panel off freezer and chip clear
Apr 13, 2015 | GE Refrigerators
About once a month the freezer has to be manually defrosted for it to work effectively.
The problem is most likely the=> 12868513 Electronic Control Board 3_11_2013_2_22_16_pm.jpg
and it could be the 12729128 Heating Element or the defrost thermostat=> W10165425 Defrost Thermostat
Here is a link to a=> GB2FHDXWB Parts Manual and a User Manual HERE The 12868513 Electronic Control Board can be found on page 6 of the parts manual and the 12729128 Heating Element and the W10165425 Defrost Thermostat can be found on page 9 I will be here to tell you how to check out or install these parts if you like, Let me know Thanks Sea Breeze
Mar 10, 2013 | Whirlpool Gold GB2FHDXWB Black Bottom...
Where is the defrost timer located on a G E side by side frig?
Your fridge does nt have a defrost timer. For the model PSS26MSRSS you will need a main board linked below.
Thanks for asking.
Main board
May 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a hotpoint side by side freezer/fridge. model #HSS25GFPJ WW, it is on the list of units with defective mother boards. i was sent a new mother board for free and i installed it. i am still having a...
Your idea may be a good idea and worth trying. I would suggest if you do so, you perform a complete shut down, 24 hours minimum. This machine has been hell on wheels. Restart and check it's progress. I would suggest that you shut off the water supply to the machine during this time to eliminate complications.
As well, make sure the lights go out when the doors are closed.
The lights go out just before the door closes.
All settings to normal.
If the problem restarts I would call G.E. factory service direct and request a free service call. They owe you.
Oct 28, 2009 | KitchenAid Architect KBFA25ERSS Stainless...
Freezer temp very unstable... lots of ice build up on inside inte
This appears to be a defrost problem. Either the defrost heater is burned out or the defrost thermostat is defective. Look into the rear wall of freezer for a layer of frost building up that will tell you that there more than likely is a large area of snow and frost building up on the evaporator coil. Once you manually defrost the coils you will be able to see the part number WR51X10038 Defrost Heater. It has a glass tube on the outside so it will be easy to spot if the defrost heater element inside is burned out. If you change the defrost heater I recommend that you replace the defrost thermostat part number WR50X10054 Defrost Thermostat. The defrost controls on your model come from the mother board so the is no defrost timer or adaptive defrost. The mother board make the decision when to defrost. When you are able to unplug and inspect the evaporator coils in back of freezer back wall panel let me know what you find, Thanks Sea Breeze
Sep 18, 2009 | GE PTS22LCS Top Freezer Refrigerator
I had a problem with refrigerator side not cold. I followed your suggestion and defrosted the freezer. The refrigerator worked for a week, now it is not getting cold. Is there some part that needs repair?
You have a problem with the defrost cycle. Your evaporator in the freezer is getting icedup and blocking airflow. I don't know your exact model but if it has a defrost timer then replace that and the defrost bimetal thermostat in the freezer. They are both cheap and easy to install. If your refrig has a control board then you will need to buy a new board because the defrost is controlled by the board. The boards are not cheap though.
Sep 08, 2009 | Kenmore Refrigerators
My heat pump doesn't produce cold air. The compressors come on but the condenser fan doesn't. Any suggestions??? Thanks George
A heat pump has more than just the contactor to contro the condenser fan, if it is getting power to the fan then repalce the fan and the capacior, if ther is no power it could be the defrost control sensor, or the defrost board, as the fan must shut off during the winter to provide a quicker defrost when in heating mode, hope this helps...
Jul 13, 2009 | Heating & Cooling
Kenmore Er dh
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Maytag MSD2756GES Side by Side Refrigerator Logo
120 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
