Question about Compaq Presario s4020wm (DK214AR#ABA) PC Desktop
My computer won't start, i tryed to put the back disk in, but that wouldn't load .
  • Christopher Frost
    Christopher Frost May 11, 2010
    we require further information to help
    what are the error messages if any when you try to start it up?
    does it attempt to read the disk? "reading from Disk drive"showing up?
    when was the last time it was working perfectly?
    any changes since then?
  • Les Ahenakew
    Les Ahenakew May 11, 2010
    is it turning on at all or do u get stuck at the windows scren?
  • 23 Answers
Most newer computers have a recovery partition. To access the recovery partition. Hold F10 at start up. Some computers use F11 or F1. Checking the flash screen at start should tell you which one to hold for recovery. Hold the proper F key at start up. When the recovery screen starts. Choose Advanced>Destructive Recovery>Follow the on screen prompts. Choosing Destructive Recovery will return your computer to factory specifications. Returning it to factory specifications will remove everything except what originally came with the computer. The recovery will take about an hour. Then go to Microsoft and, download all of the latest updates for your computer.
Posted on Apr 23, 2010
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
"Loading" screen
time for a replacement .
Jan 05, 2018 | KLH KD1220 DVD Player
How do I safely start my computer? I don't have
If you want to boot into safe mode, then press and hold your "F8 Key" while you computer is booting up this wrong bring you to a screen where you can choose to boot in safe mood.
Jan 26, 2012 | Compaq Computers & Internet
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Accidentally put mixed gas and tried to start. Blew white smoke after starting but wouldn't run. Drained tank and put premium back in now won't even start.
There will still be some fuel mix in your fuel lines and filter. Also it probably fouled your spark plug. Try changing the spark plug first, and probably buy an extra one or two to keep in case. Also either replace the fuel filter or clean it out good, oil will stick to the elements in the filter. It won't hurt anything to run a mix in a gasoline engine, just lubed things up a little extra. Let me know if you need anything else, Daniel.
Oct 13, 2011 | Polaris ATV
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
My dell Inspiron 1525 keeps stalling when loading and then I cannot do anything at all, as it freezes up.... I am typing this from my desktop I tried to system restore it...to no avail I tried to...
Try to check your disk here is a link to explain using your installation windows disk
If you don't have a disk you can probably find one on the net or borrow one..
Start your computer press F11 start from the cdrom with disk in and press r for repair when prompt
http://technet.microsoft.com/en-us/library/bb491051.aspx
You can also take the hard drive out and connect it to another computer as a second drive and run that computers command prompt.. Type CHKDSK (Your Drive: ) /F /R... on ..Example mine says CHKDSK D: /F /R press enter type Y for yes and enter don't turn off the computer.. when it is finished type EXIT and put HDD back in the another computer and start it
You can also try safe mode command prompt
After run Malware bytes to remove the mal -ware that is freezing the computer...the link Here
If you can get the malware installed and ran in safe mode you won't need to chkdsk but checking the disk is good because if fixes bad sectors on the drive also files...Made my hard drive run smoother and makes no noise..
Apr 02, 2011 | Dell Inspiron 1525 Notebook
Compaq Presario s4020wm (DK214AR#ABA) PC Desktop Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
