Question about Frigidaire PLHS267ZA Side by Side Refrigerator
No cold from last 5 days
Refrigerator did't cold .everything melt in freezer and daily fresh
    Guru:
  • 1,524 Answers
Sounds like a bad motherboard.
Posted on Apr 22, 2010
My freezer and refrigerator is not staying cold now everything on the freezer is starting to melt what should the numbers be on someone touched it an put it on freezer 7 an the refridge 5 not sure what I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | GE Refrigerators
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a roper frig that we use for vaccine storage, the freezer does not stay cold enought for their storage; if we adjust to freezer temp for vaccines then refrigerator is too cold for storage
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Mar 15, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
We have a 1999 Whirlpool side by side refrigerator and Freezer. Model number ED25EQXFW02. Last night the Refrigerator and Freezer stopped cooling and freezing. After taking everything out of the freezer,...
Usually when the freezer is still giving cold but the frig is not receiving cold you have an ice build-up on the cold (evaporator) coil that is hidden behind the rear panel of the freezer compartment. If you push on this panel, you usually will hear a cruntch sound (this tells you there is ice/frost on the coil). There are 3 components that affect this problem: defrost timer, defrost stat, defrost heat coil. In other words, something is not working to remove the frost from the coil and it is building-up day after day (takes about 5-7 days to become full (blocked). When this happens, no air can move over the coil to take the cold away and blow it throughout the frig or freezer compartments.
To access the defrost coil or stat, you have to ren move the back panel (in the freezer) and remove all the ice with a hair dryer only or let the door open all day and allow it to melt. DO NOT PUSH OR PRY OR CHOP WITH ANY TOOL OR YOU WILL BE GARRANTEED TO PUNCTURE A HOLE IN THE COIL AND YOU ARE REALLY SCREWED. The time is either: under the front of the whole refrigerator, or in the frig compartment (towards the back or attached to the ceiling of frig compartment). If you have some experience with electrical parts, you can test to see which part is at fault. Good Luck. Macgivor
Oct 11, 2009 | Whirlpool Refrigerators
My refrigerator is not cooling the freezer is working
please check the rear interior freezer wall to see if there is any ice built up.If yes,that means you have a defrost heater problem.The defrost system consists of 3 components,1)defrost timer,2)the actual heater(which is located right inside the evaporator coil compartment),and 3)a terminating stat(which shuts off the the heater before the heat cycle ends to prevent overheating).There are ways to test this with a volt and amp meter. So,if this is the case,and you need a temporary fix,and I do mean temporary,(3-5 days)you can turn off the fridge for 24 hours and leave just the freezer door open until the ice melts,OR unplug fridge,then remove the interior back panel of the freezer and melt the ice by pouring hot water over the iced up coils(CAUTION:DO NOT POKE IT WITH AN ICE PICK OR ANYTHING,YOU WILL MAKE A HOLE IN THE EVAPORATOR).after ice is melted,reassemble rear panel plug it in,and it will buy you a few days. In a refrigerator, all the cold is produced in the freezer section,then through a small hole in the dividing wall,a small percentage of cool air is blown into the fresh food section.When the coils do not defrost 3-4 times a day like they should,the air cannot pass thru them and no air will be delivered to the fresh food section. Now, if you don't see any traces of ice buildup,you may have the air exchange door in the wrong position.The air door is a little door that determines how much air is passing thru to the fresh food section.Most fridges have the selector with either numbers or letters.Example A-B-C-D-E OR 1-2-3-4-5.Now when this air door selector is in the "1" or "A" position it means the maximum amount of cold air is going to the fresh food section,which in your case,is where you want it to go. Anyway if this is the case with you, after you have made the adjustment,please wait 24 hours to take effect,it's a slow process. I hope these suggestions help you. I know I probably gave more info than you needed to know. Good luck
Aug 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Jul 28, 2009 | Refrigerators
Freezer frosting over vents, refrigerator not cold enough
Greetings,
i work on this for a living 33 years..sight unseen, I'd say the evaporator is froze over. Its missed its defrost..I suggest leave freezer door open and unplug for 24 hours to melt ice..There still will be a problem and this will continue, but this gives you temporary service. You;ll need a repair-person to fix it. The evaporator frrezes over blocking airflow to fresh -food section. This in turn can cause a fresh food and freezer failure..
Bruce Denton appliance tech 33 years...
Jun 30, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
GE MOD. TFS28PBBGBS DEFROST PROBLEM
I just had this fixed on ours yesterday. Turns out that the heating element (defrost heater?) in the freezer that melts the ice buildup daily was burnt out. They replaced it and now both the freezer and refrigerator are operating properly. Unfortunately I did not think to copy the part number, but it was a straightforward fix. I would get a professional to do it, however, because they had to disassemble everything inside the freezer and carefully melt the ice. It took about 2 hours and they charged me $235 total. Check Yelp for good appliance repairmen.
Jun 20, 2009 | GE Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
