Question about GE AZ38H12DAB Thru-Wall/Window Air Conditioner
Wall thermostat shows NO POWER, But there is power at recepticle
My GE Zoneline is not working, I operate it with a remote thermostat and have now for 2 years with out problems. It has not been needed the past few weeks and noticed last night that the unit will not operate. I've done the following checks.
1. set dip switch to ignore remote thermostat, controls on unit give no response.
2. Checked reset button on cord, it was fine, I've triped it and reset still nothing comes on.
3. varified that there is 220v at the wall outlet and there is.
How can I varify that the wall power plug is passing 220v to the unit and that it isn't defective, even though it resets fine and the test button trips the reset. I may have to call someone but prefer to check simple things first. Is there another reset with in the unit that might need to be checked or a fuse?
  • Charlie Shelden May 23, 2008
    I unplugged the unit from the was actually for an hour. Plugged it back in, made sure the selector was in the OFF posistion, then moved it to the fan mode, still nothing.
    Any other suggestions? Is there a fuse some place inside, or a reset? I'm comfortable removing panels and such, electronics is my trade so I am familar with practices etc...
    Thanks again.
    I was unable to change the condition by unplugging the unit. I made sure the power cord was still not tripped as well as made sure the selector was in the off position before I applied power. I tried it on fan and cool and heat still nothing as well the thermostate still shows NO A/C POWER.
    Thanks for any help. I'm not opposed to pulling panels and checking things, resets fuses etc...I can not find a single service company in my area that will look at it.
  • 207 Answers
Hmmm no clue needs time to reserch
Posted on May 23, 2008
  • 1,512 Answers
Try powering the whole system down for 20mins to allow for a reset of the computerised sections to occur
Posted on Mar 22, 2008
  • Graeme Ross
    Graeme Ross Mar 22, 2008
    Do this by disconnecting it entirely from the power source.
Flashes code ch09
check the control board. Make sure all plug ins are seated good if not seat them. If not I bet its your board.
Sep 02, 2014 | GE Zoneline In Wall Ptac Heat Pump Ac Air...
How do you get the external thermostat to control the unit
What is it doing now? If it works but not well it could be the postioning of the thermostat. Air flow around it must be plentiful and unobstructed. Ensure thermostat is connected to unit correctly. Using a power meter, check that you are getting power to the thermostat AND it is going back to the unit. Doesn't work if it does not send power back.
Apr 22, 2013 | GE Zoneline AZ38H12DAD Split System Air...
GE Model AZ25E09D3CM1 Serial HF 655868 No unit reponse at all regarding fan operation or compressor. Unit seems like no power supply. There is 240 vac power, 24vac supplying the outer board &...
Not certain but I believe 19 is required. Where are you reading this 16.9 and take a reading from the outdoor unit WITH OUT the wire attached and see what you get. Possibly a bad wire heading inside or weak transformer.
Jan 29, 2018 | GE Zoneline AZ35H12D Air Conditioner
How to connect to my Air conditioner AZ28E15DABm1 GE a thermostat model TR400 HC-A SECO?
carefully follow the below steps;
Turn off the circuit breaker that controls the air conditioning system. Turn the thermostat to the "On" position to make sure that all power is cut off and the air conditioner cannot accidentally operate.
Remove the cover of the existing thermostat and remove the colored wires from the terminals. Take out any screws that secure the thermostat to the wall, and remove the thermostat.
Mount the new thermostat on the wall. Feed the wires through the unit, with enough slack to allow you to make the new connections.
Connect the red wire to the thermostat terminal labeled "RH," "RC" or "R." The red wire carries the power from the transformer.
Connect the green wire to the thermostat terminal labeled "G." This controls the relay that controls the fan. Attach the yellow wire to the "Y" terminal of the thermostat. This powers the main control. Connect the white wire to the "W" terminal. This is the heating control wire.
Close the thermostat's cover and turn the breakers back on. Turn the new thermostat to the "On" position to test it and that would be all.
I hope the above helps. If it is not helpful, please let me know so that I may direct you further.....
Good luck.
Feb 25, 2011 | GE Zoneline AZ38H12DAD Split System Air...
Could be the main control board.
Could be that somebody has been messing with the dipswitches beneath the control board.
Dec 22, 2008 | GE Zoneline Deluxe Series Cooling &...
Remote Thermostat Control hookup for AZ28E15DABM1
I called out an electrician and he wired it for me. Even told me they sold me one not designed for my model, but he retrofited it and it works fine. Been about a year now.
Jun 06, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Zoneline PTAC short circuit
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Mar 29, 2008 | GE Zoneline AZ55H07D Air Conditioner
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Defective Thermostat?
well this is a very subjective question. How mechanically adept are you. If you know where to find the replacement OEM part, then its a mater of taking the control panel apart and replacing the wires one at a time from the old thermostat to the new one. It will have a sensor probe that will need to be routed and attached to the coil somewhere. The same place as the old one. make sure the bulb (if it has one) is not damaged. This may go without saying, but make sure the power is off first.
Dec 06, 2007 | GE Zoneline AZ25E12D3B Air Conditioner
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
Heating & Cooling Logo
184 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
