Question about Maytag Neptune MDE6700A Electric Dryer
Very loud squeeking noise while drying.
Sounds like a belt but appliance store said it sounded more like a spindle and bearings?
  • 523 Answers
Sounds like roolers or the ideler pulley
Posted on Apr 25, 2010
Bad oil pump ?
Turn your A/C off, the compressor can make noise if bearings are dry or system is low on compressor oil.
Remove your serpentine belt. Turn pulleys by hand to check for roughness. Bearings in those pulleys routinely go bad.
You may get computer warnings with the following test, but with serpentine belt removed, run engine for 2 or 3 minutes. Do this on a warm engine after serpentine belt is removed. The warm oil will not mask the problem like cold thick oil can. Noise generated means problem is internal.
If this is a stick shift transmission sometimes the clutch bearing can make noise and is a sign that bearing is bad.
May 13, 2013 | Ford Focus Cars & Trucks
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
How to know when spindle needs to be replaced
if you remove the belt and spin the pulleys you should hear it make noise also check the idler pulley bearing
Jun 12, 2012 | Garden
Ge profile dpsr473evoww has a VERY loud squeeking, it's not the belt as it's been replaced. Sounds like the rear bearing. What are the details of the rear bearing I need to purchase for this model?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Dryers
Loud squeeking noise when dryer starts and continues while it is drying
Greetings,
the belt pulley needs some lubricating..they squeek and the rollers thump...of coarse, its possible a stuck roller can squeek...The front needs to be removed..UNPLUG machine and if you have a removable lower access panel..this can be removed and lube the belt pulley.
if no bottom front., remove filter screws and raise top. there are two screws inside of front.Remove the front and you can lube or change parts as needed...
Jan 25, 2011 | Kenmore 66832 Dryer
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2009 | GE Dryers
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Maytag Neptune MDE6700A Electric Dryer Logo
99 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
