Question about Sanyo DS32224 TV
I broke the part that you screw on to the tv the
I broke the part that you screw on to the tv the thing that the scwer in back of the tv'
    President:
  • 196 Answers
You need a coaxial plug with number sk25fcon. but need a technitian.
Posted on May 06, 2010
How do you remove the screen from a 65" mitsubishi tv?
You have to pull the speaker cover off, and disconnect the connectors going to the OSD board, the contrlo board, and remove the scwers at the bottom of the fram and then it will take two people to lift and puul out at the same time, to remove the screen.
Aug 10, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Need to take front off to clean lint
need a make and model number on the dryer. some front load styles the top has to come off and then remove the control panel then unscrew the panel most of the have two clips about 2 inches in from each side that you would use a flat tip screw driver to pushin and then pull up the lid. and in most cases there are two scwers that hold the front panel on.
Sep 19, 2009 | Dryers
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Antenna/cable socket
yes it can be repair..You would have to take it to a repair center so they can repair it for you..
Apr 24, 2009 | Panasonic PV-C2541 25 in. TV/VCR Combo
I need to replace the mirror, it broke during transport
Take the back bezel off. It should have many screws around it. then once open you should see the back of the mirror. Carefully take the screws out of the mirror, you may have to do some modifing with the new mirror if it does not come prefabed.
Aug 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Sanyo DS32224 TV Logo
81 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
