Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Can't finish installation
I can't add my EPSONSTYLUSRX620 because it's not on the printer's
list
Brother printer dcp 110c driver - WINDOWS 7
Brother has the solution for you on their website
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000043/faq002643_001.html?reg=us&c=us&lang=en&prod=dcp110c_us&Cat=102
In case you are in a hurry to install:
  1. Click Start => Control Panel => Hardware and Sound => Devices and Printers.
  2. Click Add a printer.
  3. Click Add a network, wireless or Bluetooth printer.
  4. Select the model name and click Next.
    If the model name is not listed, follow Steps i through iii and then go to Step 5.
    1. Click The printer that I want isn't listed.
    2. Select Add a printer using a TCP/IP address or hostname and click Next.
    3. Type the IP address of the Brother machine in the Hostname or IP address field, and check the Query the printer and automatically select the driver to use option. Then click Next.
  5. Select Brother in the Manufacturer list and click Windows Update.
    While the drivers are being downloaded, the Windows Update button will become inactive. It takes a few minutes to download the drivers. When the downloading is finished, the Windows Update button will become active again, and then go to Step 6.
  6. Select the model name and click Next.
    Note for HL-1030 and HL-1230 Users:
    The "Brother HL-1430" driver is the alternative driver for your Brother machine. Select the "Brother HL-1430" from the Printers list.
  7. The model name will be displayed in the Printer name field, and click Next.
  8. Click Next.
  9. Click Finish.
Have a great weekend!
Mar 05, 2011 | Office Equipment & Supplies
How do I hook this up to my new Dell Windows 7 computer
Your solution is at this link.
http://www.brother-usa.com/lp/windows7compatibility.aspx#WinUpdate
During the initial installation of Windows 7, not all available printer drivers are listed. Clicking the Windows Update button will cause the operating system to query Microsoft's servers and download the remaining available drivers. See below to learn how to update the printer list using Windows Update.
Note: For USB and Parallel users, connect the interface cable to the Brother device while your PC is connected to the internet and the operating system will automatically download and install the drivers for your device.
  1. Open the Printers folder. Click START -> Devices and Printers
  2. Click ADD A PRINTER
  3. When the ADD PRINTER WIZARD appears, click on Add a network, wireless or Bluetooth printer
  4. Select your Brother printer from the list and click NEXT
  5. When the Install Printer Driver screen appears, click Windows Update. This will take a few minutes to contact the Microsoft server and download the additional drivers.
  6. Once the drivers list has been updated, please select your Brother printer from the list and click NEXT.
  7. Click NEXT to accept the default name of the printer.
  8. You will be asked if you want to print a test page and set the printer as the default printer. Select YES or NO. Click FINISH.
More from Brother ....
i-bluearrow_small.gifPrinters
i-bluearrow_small.gifAll-in-Ones
Jan 27, 2011 | Brother MFC-210 All-In-1 Print/...
I cannot connect my computer with a printer
The solution to connect or add the printer in your computer/PC here are the step shown below:
  1. Go into Control Panel
  2. Open or click on Printers and faxes icon.
  3. Click on File>select Add printer from the menu bar
  4. Click on Add a Local Printer
  5. Choose Create a New Port with type of port remaining Local Port, then click Next
  6. In the Port Name box type the path to the printer you wish to install to and Click Ok
  7. In the Install screen, select your printer from the list or choose Have Disk and find the location of the printer drivers on the computer then click Next and then click Finish.
  8. Now you'll see the installed in the Printers window.
  9. Right-click on the printer and click Properties
  10. On the General tab, click Print Test Page to test the printer.
You should now be able to printer from to this networked printer with any problems.
good luck thanks
Aug 27, 2010 | Computers & Internet
Can lexmark e210 laser printer be updated to run with windows 7
As this is an old model, we dont have the appropriate software drivers for Windows 7.
But, we can use the basic print and scan functionalities of this printer.
just install the printer using the steps provided below:
To install (add) a local printer
  1. Open Devices and Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then, on the Start menu, clicking Devices and Printers.
  3. In the Add Printer wizard, click Add a local printer.
  4. On the Choose a printer port page, make sure that the Use an existing port button and the recommended printer port are selected, and then click Next.
  5. On the Install the printer driver page, select the printer manufacturer and model, and then click Next.
    • If your printer isn't listed, click Windows Update, and then wait while Windows checks for additional drivers.
    • If none are available and you have the installation CD, click Have Disk, and then browse to the folder where the printer driver is located. (For additional help, consult the printer manual.)
  6. Complete the additional steps in the wizard, and then click Finish.
this works for sure..
Narendra
Jul 20, 2010 | Lexmark E210 Laser Printer
Attemts to print e-tax summary the printer is defaulting to cd
Click on startà control panelàprinter and faxes.
Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
Now, Use the drop down arrow to select USB001 then click next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish
Click on start then run type notepad.
Write any stuff and then try to print.
ADD A PRINTER IN VISTA
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select replace current drivers
Click on Finish.
Click on start then search type notepad.
Jul 12, 2010 | HP Photosmart Premium C309A All-In-One...
Its identifying my printer as being offline, how do I correct it
Click on Finish
Click on Finish.
Jul 10, 2010 | HP Officejet 4315v All-In-One InkJet...
My Epson LQ300+II printer does not print via USB from XP SP3 - DG31PR Intel Mbd. Someone pls urgent help pls...
Solution 1
Purchase an LPT printer port (PCI Slot), get it fixed on your motherboard. And follow the steps :
- install the PCI slot driver
- Goto Device manager, select properties for PCI Slot. there you need to change printer port from LPT3 to LPT1
- Goto to printer driver properties and there also you need to change printer slot from LPT3 to LPT1
Solution 2
1) Install the Microsoft Loopback Adapter
a) In Control Panel, double click on Add Hardware.
b) Click Next
c) When the scan finishes, select "Yes, I have already connected the hardware"
d) Click Next
e) Scroll to the bottom of the list and select "Add a new hardware device"
Click Next
f) Select "Install the hardware that I manually select from a list (Advanced)"
g) Click Next
h) Select "Network Adapters"
i) Click Next
j) Select "Microsoft" under the Manufacturer list.
k) Select "Microsoft Loopback Adapter" in the Network Adapter list.
l) Click Next
m) Click Next
n) Click Finish
2) Configure the Adapter
a) The loopback adapter is a virtual network adapter and can be configured the same as a regular network card.
b) Set the adapter to have a static IP address such as 192.168.1.1/ 255.255.255.0
3) Share the printer.
a) I recommend you use a share name that you will remember. I used “Printer” in the new machines that are already deployed.
4) Capture the printer port.
a) NET USE LPT1: \\[Computer Name]\Printer /PERSISTENT:YES
Mar 20, 2010 | Epson Dot Matrix LQ-300+II Printer
Is the HP LaserJet 4Plus compatible with Windows 7?
if it has a vista driver it is... vista drivers work on windows 7
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | HP LaserJet 4 plus Printer
How do i add my printer.
Plug in the printer & run the disk. That's it!
Aug 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
