Question about Vivitar ViviCam 8300s Digital Camera
Why does it tell me memory card error with a new 4gb card
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 24, 2010
I put a new 4gb sandisk hc memory card into my jvc gr d270u video cam and i get card error message with or without the card unlocked.i can not go to the format menu with the card in place.
Hardware of this camcorder supports up to 2GB memory card so 4GB is more than its capacity and causing error.
Try 1GB or 2GB memory card in camcorder.
Thanks.
Jul 13, 2010 | JVC GR-D720 Mini DV Digital Camcorder
I were on holidays last weekend and after taking about 600 pics,when i want to review my photo,the screen started telling me there was an 'error with memory stick'. Now it's telling me 'error formating...
wow, that's the first time that I heard of a Memory Stick Pro 4gb failing for someone. Try to take the memory stick pro to Walmart photo center to see if they can read the pictures. If they can't (or your local drug store) I don't know who can.
Good luck on this.
Jul 21, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Card error on new 4gb card
Go to this link and follow the instructions to update your camera's firmware to be compatible with High Capacity memory cards.
http://www.fujifilm.com/products/digital/download/a820_a825/fupd.html
Feb 06, 2010 | Fuji FinePix A820 Digital Camera
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
Memory card error
Format the memory card in any other camera or pc.
Aug 27, 2009 | SanDisk 4GB Secure Digital High Capacity...
Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
May 16, 2008 | SanDisk 2GB microSD Memory Card
Vivitar ViviCam 8300s Digital Camera Logo
106 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
