Question about Dryers
Clothing dryer. Heat comes on and then after a short while turns off. I can see the ignition element heating up and I also hear a clicking/rattle noise. The gas does not ignite. Air goes cold. If I turn the dryer off for a while, turn it on the heat comes back for a short while. I recently replaced the thermal resistor and just now have replaced the cycle thermostat. Problem persists. What do you think this might be?? Does the cycle thermostat have to be wired up in a special order? There are two sets of wires - one set of two matching red wires with small terminals and another set of two matching blue wires with larger terminals. They seem to fit correctly on the terminals of the thermostat - just wondering red-to-termal and/or blue to terminal order is important. Is there anything else that might be causing the dryer to heat, then lose heat? What about the rattle/clicking noise?
  • 1chris_andre Apr 22, 2010
    Yes - very helpful.
    This was a well thought out reply which took into account the symptoms and observations I supplied and gave me a route to follow and ways of checking to determine the problem's cause. Well thought out, very clearly written, I believe I can now figure out what is wrong and likely fix my dryer. Thank you local wonder!
  • 6,784 Answers
Hi. That rattling noise is a very strong indication of a failed set of gas valve coils.
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will not heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Posted on Apr 22, 2010
Maytag gas dryer flame comes on but will not stay on
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
We had ours replaced several years ago by a reasonably priced repairman. It bought us another 8 hears on our dryer!
Jul 27, 2011 | Dryers
My whirlpool model LTE5243DQ6 is not heating up. i turn it to the max heat and it doesn't heat up. it turn on and i could hear the clothing moving but it not heating up.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps... Please post back if you need more information.
Daniel
Feb 10, 2011 | Washing Machines
Dryer has lost heat.
Hi
Electric Dryer---
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Dec 11, 2010 | Kenmore 700 6972 Dryer
Maytag gas dryer. Heating element comes on however, not every time does the gas click on so I get heat. Gas line is fine. What causes the click that gets you heat for dryer?
That would be the "igniter" you hear. You may have a problem with the igniter or the 2 coils on the gas valve. Below are links to the parts.
Igniter
Coils
Nov 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
The dryer is not heating up or drying clothes. I read another person said it might be a burnt out heat element. How would we check for this.
With no heat comes no dry clothing. The heating element is not coming on, it could be the thermo cutoff(fuse) is burned out, that is alot less $ than the heater. You will need to check with a ohm meter, pull up veiw of part location by use of model# on any parts web page.
Sep 29, 2010 | LG DLE5977 Electric Dryer
No heat and a clicking noise when trying to light
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru troubleshooting this. It's a different model but the troubleshooting is the same. You can also enter your model 3 for diagrams and illustrations of your specific model.
May 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Amana PLE8407W2 doesn't heat.
If the fuse rattles, that doesn't sound good, but the easiest way to check is with an ohm meter, or multimeter which you can get at walmart for like $10, and you should own one anyway.
Oct 15, 2009 | Dryers
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
Heat kick on then off
these are heat cycles,
the click you are hearing is the thermostat turning the element on or off, most dryers try to acheive a temp of 160 - 180 degrees, when reached the element shuts off for a bit to cool down and not scorch your clothes
you do not have to worry about this
May 26, 2009 | Kenmore Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
