Question about Nikon D50 Digital Camera with 18-55mm Lens
Need help using the wireless cable release - Nikon D50 Digital Camera with 18-55mm Lens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
I assume you're refering to the ML-L3 wireless remote control.
Change the shooting mode on the camera by holding down the shooting mode button and turning the main command dial. You want either delayed remote or quick-response remote. The quick-response remote fires the shutter as soon as you press the button on the remote, the delayed remote gives you two seconds to hide your hand behind your back before the camera fires.
Posted on Apr 23, 2010
How do I use a wireless shutter release for a ninon p510
You don't. The Coolpix cameras do not have the electrical receptacle necessary to connect a wired or wireless shutter release. If wireless release is important, you need to upgrade to an SLR. You are looking at $500 and more unless you buy used equipment.
Jul 06, 2014 | Nikon COOLPIX Cameras
WAN light keeps blinking on my Wireless N Home Router and I cannot access the internet although I can access the router config page. This started just yesterday and before that the WAN light used to be...
How old is the device? May be time for a new device? Has there been any electrical storms? Power surges? Tried different connecting cables? When you reset the device, hold reset for 30 secs., release, wait for selftest, unplug device for 30 secs., plug in, wait for selftest, connect with a Ethernet cable, reconfigure SSID and Security Key.
Apr 28, 2013 | Trendnet TEW 652BRP Wireless N Home Router...
W fi will no longer connect
The wireless router has a rest button, just reset it, you will need to reset security, if you use it.
To rest ip, you use ipconfig/all
ipconfig /release
ipconfig /renew
exit
But if you just reset router, repower this and the cable modem, you should see the wireless, then if you have to, open network and sharing, change adapter setting, disable and enable the wireless hardware.
Apr 12, 2013 | HP Compaq Presario R4000 Notebook
Internet conexionlocal only
Wired or Wireless? If Wireless will not connect, First try a test, using a Ethernet cable connect directly to the ISP modem, Does it connect? Yes or No? If yes, move the cable to the Wireless router, Does it connect, Yes or No? If no, Contact ISP. Check ALL cables to the ISP and Wireless device ,reseat cables. It may be the Laptop Wireless or wired adapter, reboot the laptop and the wireless device. I don't have all the info needed to supply a more percise solution. Try a IP release and renew using this procedure : http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/
Jan 29, 2013 | Acer Aspire 7720 Notebook
MY LAPTOP AND PHONE BOTH FIND MY ROUTER BUT WIIL NOT CONNECT, ALL THE LIGHTS ARE GREEN ON ROUTER! I'VE TAKEN THE ETHERNET CABLE OUT MY PC (PC NOT TURNED ON FOR A YEAR!) AND CONNECTED IT TO LAPTOP AND...
It is possible that there are restrictions on your wireless router, do you remember setting up a password? Anyway, to completely remove any restrictions from wireless connections, just reset your router. To do that you need to do the following:
•Unplug all LAN cables from the router.
•Unplug the router power cord connector from the back of the device.
•Using a paper clip or something similar that will fit into the reset hole, press continue to hold the reset button, then carefully reinsert the power cord, making sure not to release the reset button in the process.
•Continue to hold the reset button in for at least 15 seconds after inserting the power cord, then release it. After about 10-25 seconds the router will boot and it will be set back to the original factory default settings.
By default the password on the router is left blank, and the default IP address is 192.168.2.1
I hope this will solve your problem.
You can rate my answer if this helped you.
-damneddle
Oct 06, 2011 | Belkin (F6D42304) Wireless Router
How to set a password ?
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 25, 2010 | Linksys WRT160N Wireless Router
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
Can't get it networked on my mac that has windows parallel xp cant find it
Hi
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
Problem: Cannot get network on the Mac not specified
OS : MAC computer Windows installed on it
Printer Office jet 6500 Wireless.
Solution :
There are few thing which are required to know before we start trouble shooting
IMPORTANT : Before you can install the product, your wireless network must already be set up. (To set up your network, follow the instructions that came with your particular access point.)
IMPORTANT : Before you can install the product, you must have the following information about the network:
  • Network name : The network name is the SSID (Service Set Identifier).
  • Password : WEP key or WPA passphrase
For a new product:CD installation is a quick and easy method and if you do not have a CD, you can download the software you need.
CD installation : CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released as the software on the CD is current to the date of the product release.
Downloading the HP Drivers :Downloading the software provides the best results for your older product. Even though it takes more time than using the CD, downloading the latest software can help you avoid installation issues. Downloading is also the recommended method if your computer operating system released after the HP product released. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market ..
Wireless installation: If you have not previously installed the software, follow these instructions.
Step one: Prepare for installation
1 Make sure that you have the following requirements before you begin:
  • Network name: The network name is the SSID (Service Set Identifier).
  • WEP key or WPA security passphrase
  • A computer that is connected to the wireless network.
  • Internet access. HP recommends broadband Internet access such as cable or DSL.
  • Your wireless-capable HP product. Place it close to the computer during the installation procedure.
  • A USB cable (used only during installation).
  • Administrator privileges or password
2. Make sure the product, access point, and computer are all on, and that the computer is connecting to the wireless network.
3. Connect the USB Cable to the rear port of the HP product and to any USB port on the computer.
4. Exit all applications running on your computer.Install the software
To install the product software, follow the steps for the method that you want to use (CD or download).
Method one: Install the software with the software CD
  1. Insert the Macintosh product CD into the CD drive of the computer.
  2. Double-click the HP software disc icon that displays under the Xp/Macintosh HD icon.
  3. Double-click the HP Installer icon. The HP Installer program opens.
  4. Follow the on-screen instructions to start the installation.
  5. When prompted to set up your device and software, select Continue .
  6. If a check mark does not appear, select Configure your device for a wireless network , and then select Continue.
  7. Follow the on-screen instructions to finish installing the software
Option two: Change connection type
1. Open HP Device Manager.
2. From the Information and Settings drop-down menu, click Setup Assistant . 3. The HP Setup Assistant window opens.
4. Follow the on-screen instructions to change your connection type to an existing wireless network.
Jan 04, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you use a remote shutter release for a canon d 50 slr , and where do you find the timer on same camera?
You need a remote shutter release button attached either via a cable, or wirelessly. Canon make several models, as do many third parties.
As for self timer, press the AF-Drive Button then use the select wheel to move from single shot to high speed, slow speed or self-timer modes.
Feb 19, 2009 | Canon Cameras
Linksys wireless G-ADSL Home gateway
Sometimes this happens. Installing the Linksys software for your router helps a lot. To reset the router. Unplug the power cord from the wireless & unplug all cables to it. There is a reset button on the back side of the wireless. It is very small. Using a pen press & hold for ten seconds or so. Release & connect your cables & than the power cord. Never hurts to restart the pc or notebook. If you still need help you can check out Linksys home page for wireless G routers.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
There is a decent ammount of help, a larning center & driver software.
Luck!
Please vote....
Jan 19, 2008 | Linksys Wireless-G WRT54G Router
Nikon D50 Digital Camera with 18-55mm Lens Logo
75 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
