Question about Music
I have a rhodes 660, and it doesnt trun on. all u hear is a buzzing sound. does anyone know whats wrong.
  • Music Master
  • 5,603 Answers
This is LIKELY a power supply problem. The unit should have a label telling the power requirements. Match the polarity on DC units as well as the type AC od DC and voltage and current.
I suspect the input voltage from the supply is way lower than the required.
Posted on Apr 28, 2010
Replacing ac power adapter.
If the polarity, voltage, and amperage are the same, there is no reason that you cannot use this device as an alternate.
Oct 16, 2016 | Roland Music
I am hearing a buzz when i turn on the mic. What's the solution, can you let me know please?
Buzz is almost always a grounding. Check the soldering. If you are not comfortable with that get a known working mic and cord and try that out.
Nov 29, 2014 | Roland Boss Micro BR Multi Track Recorder
Only humming or buzzing , no music or sound
Try different cables. That would be the most simple and cheapest fix.
May 27, 2014 | Roland Kc-150 65-watt Keyboard Amplifier...
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
Amp buzzes all the time
Make sure the ground plug is not cut off of power plug. Also, if the power switch moves in 2 directions, it is a ground reverse, meaning switch it the other way. If it doesn't, look for a ground reverse switch somewhere on the back.
Mar 05, 2013 | Music
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
I turn on the power and get just a buzzing noise. The keyboard does not work at all. The power light is on but no sound from the keyboard other than a buzzing sound.
normally a buzzing sound means a grounding problem, or a component has failed, unless you have the proper equipment to check these items,, your going to have to take it to a shop that does, sorry I know thats not what you wanted to hear,, but heres a hint, Ive found that a shop that deals in instruments and sound devices charges a lot, I have found a TV repair shop in my town, that can check my band equipment,, and its much cheaper, and I usually get the stuff back much quicker too
Sep 01, 2011 | Akai Music
Whenever I use one of the cleaner amp models i get an aggravating buzz. The buzz only occurs when I play and is not constant. (The buzz is not there when I'm not playing). At first I thought my strings...
Try moving your guitar around and oriented differently as it MAY be picking up magnetic fields from equipment in the area. Some pickups really are sentive to interference.
The effects for modeling MAY have a noise gate that requires a certain signal level before unmuting which would explain why you have to be playing to open the gate and hear noise that is really there all teh time but muted.
Dec 27, 2010 | Line 6 POD HD500 Amp Modeler and Multi...
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have a Roland Rhodes Model 660 keyboard/synth and cannot find a user's manual
www.rangeraudio.com has a good selection of manuals.
Apr 23, 2009 | Music
Music Logo
131 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
