Question about Kenmore 74832 Gas Dryer
Sometimes it heats and sometimes it doesn't and sometimes it leaks gas
  • 218 Answers
Your problem sounds like either a bad safety gas valve or a bad coil on the valve.
If i can help with anything else please let me know.
Posted on Apr 22, 2010
Testimonial: "i found the original parts book that came with it, now hopefully we can fix it."
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
DOESNT HEAT AND I SMELL GAS
Hello - From what you are describing, if the dryer only heats up sometimes but provides a gas odor, it could possibly be a defective gas supply or igniter. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If it proves to be ineffective and if the issue continues I suggest contacting a professional to move forward accurately. Keep in mind since it is such a complex unit, the technician will likely verify that it doesn't have a defective sensor, control board or high limit thermostat.
Oct 13, 2012 | Frigidaire GLGR341AS Gas Dryer
Evap system leak
First thing everyone tries is a new gas cap. Sometimes it works and sometimes it doesn't, but it's the easiest thing to try. Did you drive it with the gas cap off or maybe loose? That will trip the code and it will take a few ignition cycles to clear it or have a shop clear it with a scan tool and drive it some more. EVAP codes on GM vehicles can be a pain to locate if it's anything more than a gas cap issue. Don't buy an aftermarket gas cap though. Spend the extra few bucks and get an OEM one.
Sep 22, 2012 | 2001 Oldsmobile Alero
Electric dryer doesn't get hot?
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Oct 15, 2011 | LG DLE2514 Electric Dryer
I have a kenmore elite model #110.95088400 that doesn't heat when drying. I checked the thermal fuse and it goes to continuity. I checked the hi limit thermostat and it was continuity, the thermistor...
heatman101
Aug 24, 2011 | Dryers
My dryer is not heating up. The ignitor glows but the gas does not ignite. I took of the front lower panel and watched it. It doesn't ignite. The gas line is fine. What can it be?
heatman101
Aug 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
Have gas smell outside and sometimes inside car. Some one said could possibly be cabin air filter?
Hi there!
Usually when the car doesn't burn the gas as it should and the cylinders gets flooded with gas and this can be caused but a leaky Injector or a Bad MAP sensor, Vacuum leak or bad fuel regulator.
Good luck
Jul 02, 2011 | Saturn L-Series Cars & Trucks
My pool heater doesn't come on. The pilot is lit, and the valve to the ON position. I turn the front knub to heat but when I turn the switch on the front panel to ON it doesn't fire on (...
If your pilot light is lit, then you do have some gas flow, so it is probably the thermocoupler (the part heated by the pilot light) that is not telling the gas valve to open the main line. Sometimes it is just a case of residue on the thermocoupler that is not letting it get up to temperature and sometimes it has been knocked out of alignment and the pilot light is not putting direct heat on it.
A cleaning with steel wool (don't overdo it) would take care of the residue, and you can GENTLY move the thermocoupler back over the pilot flame. If neither of that helps then replace the thermocoupler.
Jul 01, 2011 | Hayward 250 1 Millivolt Propane Pool...
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore 74832 Gas Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
