Question about Ricoh Aficio 2018D All-In-One Laser Printer
How do I connect Ricoh 2018D to recive fax and how do I scan. I cannot locate the manuals
mrveder
  • 3 Answers
SOURCE: Fax confirmation
Hi TUlsi The majority of fax machines will do this, I know as the ones i use in DHL are the same when i contacted the company Cannon they advised that it could not be disabled. Which give the solution, All faxes are different and you will only know how to disable it by contacting the manufactures support. I agree full it is anti enviromently friendly and a waste of ink
Posted on Mar 09, 2007
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
SOURCE: i am having trouble scanning
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Posted on Feb 14, 2009
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
  • 3278 Answers
SOURCE: trying to scan w/ Ricoh Aficio SP C210sf
Could be a driver issue. Go to: http://www.ricoh-usa.com/downloads/software.asp?tsn=Ricoh-usa and find, download and install the driver for your Ricoh device.
Posted on Jun 11, 2009
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Ricoh Aficio 2018D - previously used a scan router software to scan to file on Windows server. Now being told Windows server 2008 is not compatible. We are using scan to email but very cumbersome. Is there...
No, all the newer machines have imbedded scanning. The scanrouter software was an old product and only supported through 2k3 server. I would setup an old PC with the scanrouter and whatever platform you were running before and use it just for scanning. You can install it as a service so it will run on its own.
Feb 02, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Dont know how to configure scanner on Ricoh Africo 2018d. It is set up as a network printer atm
There are a few ways, such as configuring "SMB", "Scan to "Email" and/or installing "Scanrouter", but they are too involved to explain here.
The other is the "Network Twain Scanner" which, once installed, you can use a program such as "photoshop" , or many other photo editing softwares to scan. Simply open the program, click "file", "Import" and you should see the scanner as an option, make your settings, and go.
You can get the software here. Just select your operating system. It will need to be installed on each PC:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x2015_18/x2015_18en.htm
Mar 06, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh 2018D
press [user tolls/counter] and then before you press the system features press it and hold the [#] button and while you hold the [#] button press [OK] the copier will ask you do you want to return the setting to default or not.
This procedure you may make and for the fax setting and for the printer settings.
After this the machine will bring the settings to the default
Feb 23, 2009 | Ricoh Office Equipment & Supplies
Wrong Settings on Ricoh 2018d Nashua
1.Press [user tools/counter] key .
2.Press and hold it pressed [#] key.
3.While you hold down pressed the [#] key press [OK] than the copier will ask you do you like to return the settings to default or not.
This procedure you will have to repeat to all the features.
example : [system features] or [fax features]
remember while on the display writes [fax features] you should hold it pressed the [#] key and while is pressed he [#] key press the [OK] key ones .
Feb 20, 2009 | Ricoh Office Equipment & Supplies
Add group dial for faxing
you can get the manual(s) here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/x2016_20/x2016_20en.htm
Feb 16, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
Sorry:(
Dec 08, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Adding an e-mail address to my Ricoh Aficio 2018D
I found the manual on the web for General Operations and found what I was looking for. I have all the manuals but the one I actually need.
All is good.
Aug 28, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Fax function doesn't work
check your phone lines.then connect it to the machine.press on hook dial.if dial tone is not there you may need a service engineer.
Apr 05, 2007 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
203 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
