Question about Brother MFC-9440CN Laser Printer
Ok anyone know how to reset the Drum on a Brother MFC-9440CN ???
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
jtuminaro
  • 56 Answers
SOURCE: Need to reset 'Drum near end' warning on Brother MFC-8460N.
Open the front door
Press clear
then press 1
Posted on Jan 15, 2009
jtuminaro
  • 56 Answers
SOURCE: RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
techbuster
  • 5081 Answers
SOURCE: How do I reset the drum counter on MFC-9440CN
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
Posted on Aug 31, 2009
Testimonial: "THANK YOU THANK YOU THANK YOU Quick response and WONDERFUL HELP TO START MY MONDAY:)"
  • 8064 Answers
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Posted on Sep 03, 2009
My Brother mfc 9440cn is printing a ghost image. how do you fix this?
The most common remedy is to clean the drum unit, but you have replaced that. Try cleaning the corona wires, p144 here
http://www.manualsprinter.com/manuals/brother/Brother_MFC-9440CN.pdf
Jan 11, 2015 | Brother MFC-9440CN Laser Printer
Drum error message
Hi anandongol,
Kindly follow the steps below to help you reset the drum error message for Brother MFC-9940CN:
  1. Turn the the machine's power switch back on.
  2. Press Menu > Machine Info. > Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
Hope it helps.
Thank you for using FixYa.
Apr 27, 2011 | Brother MFC-9440CN Laser Printer
There is no reset menu on my MFC 9440CN ?? I want ot reset the drum unit as I have replace it with a new one
Press the MENU key on the control panel
Press the Up or down Arrow key to select " Machine Info ":
Press OK
Press the Up or Down key to select Reset Menu
Press OK
Press the Up or Down key to select " Drum "
Press OK
Press 1 to reset the drum unit counter .
Good luck . wilson with Wilson Business Machines
Feb 09, 2011 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
Drum error
Try replacing the drum. After this operation you have to reset the drum unit counter. Use the following steps in order to do that: Press Menu =
Aug 25, 2010 | Brother MFC-9440CN Laser Printer
What does drum end soon mean? Status monitor for my brother MFC-944)CN printer is saying Drum end soon! the file is being sent the status says ready, the paper goes through and comes out blank!
1. replace drum unit
2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
resetting without actual drum replacement might damage your printer.
Jun 29, 2010 | Brother MFC-9440CN Laser Printer
How do I reset the drum counter on MFC-9440CN brother
  3. Press OK.
  5. Press OK.
  7. Press OK.
Aug 31, 2009 | Brother MFC-9440CN Laser Printer
Cannot reset drum counter after fitting new drum
Instructions for resetting the drum count can be found on our web site at:
www.ccl-la.com/brother.htm
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | Brother MFC-9440CN Laser Printer
Drum error
You need to replace the drum.
May 27, 2009 | Brother MFC-9440CN Laser Printer
How do you reset the drum counter for a Brothers MFC-9440CN?
  3. Press OK.
  5. Press OK.
  7. Press OK.
Jan 13, 2009 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
