Question about Kitchen Ranges
We have a Sylvania Mod SR11092. After setting the time and starting the unit, it quits & the screen goes blank for several minutes. The the clock comes back on and it is again usable for 2-3 minutes.Is it safe to use & what might be the problem?
  • scottmarilyn Apr 22, 2010
    I' d like a second opinion and if the answer is the same, how do I replace the control panel, or should I even try.
  • 10,515 Answers
It seems like a Control Panel. But, would like to Share some Details :-
1. There could be many Other Possibilities for the same. I do buy the information given by the first expert, However, as we discuss there could be other Possibilities.
2. This is an Expensive Part and there is NO WAY to test the Credibility of the Part. After making sure that, there is no Other Fault, we usually Order the Part. As we Cannot see the Machine, we could only make an intelligent guess.
3. It could be a loose or Faulty Connection. But, i would advise you to Set up a Repairman rather than replacing Control Board ( This is usually Non Refundable ).He would be able to eliminate all Possible Reasons by looking to your machine on site.
4. Regarding Control Board Replacement, it depends on Person to Person.It is not Difficult but if you are doing it for a First time, chances are that you might mess up. Again, as i said, it depends on How many times you worked or How efficient you are with all the electrical stuff.
Note - If Possible, Unplug it for Few Minutes, say 30 minutes and then Turn it ON. This would reset the Machine.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 22, 2010
  • 1,284 Answers
Hi, to be on a safer side, it's not really safe using the unit because i has a faulty control board panel, that's why the screen goes blank for some minutes and returns back again.
All you have to do is to replace the control board panel..
Take care
Setting clock on Sylvania SCR4986
This is what i found:
Clock Setting
The clock can be only set while the unit is in standby mode
1. While the unit is in standby mode, press the TIME_SET button into clock setting. The LED
display will start flashing, press REV/DOWN or FF/UP to select 12h display or 24h display.
Confirm your setting by press TIME_SET again
2. While the unit is in standby mode, press and hold the TIME_SET button for 2-3 seconds, the
hours will start flashing, press REV/DOWN or FF/UP to set the current hour, press the
TIME_SET button to confirm the setting, then the minutes will start flashing, press
REV/DOWN or FF/UP to set the current minutes, press the TIME_SET again to confirm all
setting. The time is now set
Drew.
Jan 14, 2015 | Sylvania Audio Players & Recorders
Green light blinks 15 times and the screen goes blank
To try to help I need the brand and model number, you can also try to remove power from set and or a box if used for several minutes and then plug back to see if when they reboot the set works or not.
Dec 10, 2012 | Televison & Video
My screen goes blank whenever I try to watch a TV show online. How do I fix this?
Check the power options in control panel on the start menu and adjust settings. Sounds like the screen is set to go off after a certain time if there is no activity.
Apr 14, 2012 | HP Pavilion dv7-1245dx Notebook
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
Tv goes blank while viewing
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that re-starting that gives it away, this is a typical switchmode Power Supply problem.
Jan 24, 2010 | Televison & Video
Received Kodak 8.1 last April. Now it freezes
1. Go into the menu and find "reset"...follow the on-screen instructions. 2. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 05, 2010 | Cameras
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Aug 30, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
