Question about Frigidaire ATF6000ES Front Load Washer
Need to replacedoor lock sensor on model aftb7000epo
    Scholar:
  • 126 Answers
THERE IS A TINY SPRING CLAMP THAT GOES AROUND THE GREY RUBBER BOOT AT THE DOOR OPENING. THE BEST WAY TO REMOVE THIS IS AT THE BOTTOM 6 O'CLOCK POSITION. THEN UNATTACH RUBBER BOOT FROM DOOR OPENING.
Posted on Apr 24, 2010
Oven door is locked after self cleaning still. And is showing F 3 code.
Is this a whirlpool product need model number F3 for a whirlpool product is cavity sensor says check sensor connection if good change sensor if problem persist change control board
Feb 17, 2015 | Kitchen Ranges
Oven will not unlock after self clean
Unfortunately, the high temperature limit sensor probably failed during the self-clean cycle. The oven control unit will not receive the signal that the oven is cool enough to unlock the door without the sensor.
If the oven is cool, you can try unplugging the oven for a while and then see if the oven unlocks after power is restored. Pressing the Cancel button several times (or pressing and holding Cancel, depending on the model) may also work. Sometimes, starting a new cleaning cycle and then stopping it (and waiting for the oven to cool) will work.
However if the sensor has failed, the above steps are unlikely to work. You can try to move the lock manually. On some models, you can use a bent coat hanger to slide between the oven door and the frame and push the lock over. On other units, you might open the back panel and rotate the lock mechanism cam.
The oven will not work until the high temperature sensor is replaced. Sometimes the lock mechanism fails and that is what needs to be replaced. If the oven works, then look at replacing the lock motor.
I hope this helps. If your oven is under warranty, contact GE for the repair. Please add a comment with the model of your unit for specific information on the parts you may need.
Dec 29, 2013 | Ovens
I have an LG Tromm washer, model wm2277hw. I am getting an "LE" code what does it mean?
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...please post back for further assistance.
Daniel
Sep 24, 2011 | LG WM-2277HW Front Load Washer
How do you replace a lg drain pump for model WM2277H? Washer shows error message LE and will not drain
Hi
Daniel
Aug 06, 2011 | Washing Machines
Unti lock on all time. sensors cleaned.
Maybe the anti lock brake ecu is bad or the sensors need to be replaced on the appropriate wheel as indicated by fault codes for the ABS system.
Fault codes were not provided on the original 1989 model of the Saab 9000, but the 1990 to 1991 model ecu can be installed and fault codes read from the AntiLock warning lIght flashing codes.
Check wiring to ensure there are no opens to the module from the ABS Wheel Speed Sensors.
Maybe check that the wheel speed sensor is picking up a sinusoidal wave of AC electricity when the wheel is spun as seen on an oscilloscope function of a multimeter. This would isolate the problem to wiring or the ECU being at fault.
Oct 29, 2010 | 1989 Saab 9000
ATI LOCK LIGHT ON BRAKES WORKING BUT DONT FEEL THE SAME AS NORMAL
Check Brake fluid level.
When the ABS light is on, the brakes should revert to standard braking.
The only time ABS should invoke is when the tires are slipping as sensed by the wheel speed sensors when the wheel locks up on any of the axles.
ANTI-LOCK BRAKE SYSTEMS General Information Fig. 1: RWAL brake system diagram
Fig. 2:4WAL Component locations — except 1996 models
p>Fig. 3: 4WAL Component locations — 1996 models Fig. 4: Three sensor 4WAL brake system diagram — Except 1996 models
Fig. 5: Four sensor 4WAL brake system diagram — Except 1996 models
There are two basic types of anti-lock systems available for this vehicle; a Rear Wheel Anti-Lock (RWAL) brake system and 4 Wheel Anti-Lock (4WAL) brake system. The 4WAL system has two variations; a 3 sensor system and a 4 sensor system. The 2WD vehicles will be equipped with the 3 sensor system, but the AWD vehicles can be equipped with either. The systems are easily identified by looking at the rear wheels for a sensor harness. If there is a sensor harness and thus, rear wheel sensors, it is the 4 sensor system. If the vehicle is not equipped with a harness, it is the 3 sensor system. The 4 sensor system takes it speed references from each of the wheels. The 3 sensor system takes its speed references from each of the front wheels and the vehicle speed sensor located in the transmission (2WD) or the transfer case (AWD). The RWAL system components consist of the Vehicle Speed Sensor (VSS), the Electronic Control Unit (ECU), the isolation/dump valve and the Vehicle Speed Sensor Buffer (also known as the Digital Ratio Adapter). The ECU also receives signals from various brake switches. The 4WAL system components consist of the Electro-Hydraulic Control Unit (ECHU) valve (also known as the Brake Pressure Modulator Valve or BPMV), the wheel speed sensors, Vehicle Speed Sensor (VSS) on 3 sensor systems and the VSS Buffer. prev.gif next.gif
Sep 01, 2010 | 1993 Chevrolet Astro
Lg washing machine, model no. wm-1280 keep on getting error code LE, some people are saying its the sensor (which i'm dubious about) and others are saying motor or bearings....... erm help
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it’s not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Sep 01, 2010 | LG Washing Machines
NEW MACHINE - IT SAYS RELEASE THE SENSOR LOCK WH...
what model is your printer? if your printer is those AIO printer, which means it comes with a scanner.. you will be able to find the scanner lock at behind or side of the scanner...
May 20, 2010 | Office Equipment & Supplies
DOOR AJAR LIGHT (bad sensor?)
I'm pretty sure that they are integral to the door lock assembly on that model, would need to replace the whole door lock if that is the case. Best to get the Ford dealer to plug in their computer and check the signals from the door locks to see which one is at fault. Check central locking and power mirror fuses first, if no power to door locks then the door ajar sensors will have no power as well.
Oct 25, 2008 | 2003 Ford Explorer
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Frigidaire ATF6000ES Front Load Washer Logo
76 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
