Question about Maxtor Hard Drive
Slave drive how do I install a new hard drive into my xp pro dell desktop system? if you can please be very detailed, so that I don't make any more stupid mistakes than I already have. thank you in advance for the help.
  • 871 Answers
If you do know how to install hardrives to your computer, this will be fairly simple.
check the back of your hard drive and look for the pins. there will be a connector there that will indicate if the hard drive is a master or slave. put the jumper into slave.
after doing that. connect your hard drive to the ide cable. since it is a slave hard drive, put it in the 2ndary ide slot on that cable. you can either do this on the primary ide cable or the 2ndary ide cable.
restart your computer.
done
Posted on Mar 23, 2008
How do I replace hard drive in dell OptiPlex 360 with Seagate barracuda 160 gb 7200 sata hard drive?
Do you want to replace it or add it as a slave drive....is your hard drive bad or just limited use...there are different jumpers that need to me set for different way of installation....do you have a new license for installing an operating system....several questions come to mind...I've replaced several and added slave units but it differs.....Can you give me more details and I may be able to assist you with your endeavor....Do you have an alternative method for accessing the internet or better yet, fixya website?
Oct 18, 2013 | Dell Dimension 2300 PC Desktop
It is running very VERY VERY slow. I thought reinstalling windows xp and drivers may solve problem but did not. I booted the system from C drive with windows xp pro in he system. It formats the hard drive,...
You may want to check the hard drive - sounds like it may be starting to fail. When it reaches the point of not continuing does it start to click? If you hear clicking then the drive is having issues and its time for a new one.
Nov 15, 2009 | Dell Dimension 4600 PC Desktop
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Bad dell hard drive
as long as you have the windows COA code on the back of the computer (certificate of Authenticity) you can just find a good copy of XP Pro, and install it on your machine. When done, you can run the resorce CD and install the drivers.
If you do not have the Operating System disk, you have to find another disk, or contact Dell to get a new one sent to you.
The key is that you have the code on the back of the computer (or top, or side, or wherever.)
Apr 06, 2009 | Dell Dimension E310 PC Desktop
Can't install WINDOWS.
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
The motherboard cannot detect the hard drive/ hard disk
You cant install xp on one machine and then move the drive to another. By nature the xp install is tied to the hardware of the machine it is installed on
May 22, 2008 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
New hard drive(s) in Dell4500s
You would have to contact dell for the OS disk.
I dont think you can install the hard disk in place of floppy drive. An external Hard disk would be a better option.
May 04, 2008 | Dell Dimension 4500S PC Desktop
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Installing Windows XP on new drive in HP a220n
Your new hard drive has a name, like Seagate, Western Digtail, bla, bla... Go to the Mfg's web site for your drive. Download the bootable floppy disk manager setup utilities. If you have a floppy disk drive. If you don't have a floppy drive most Mfg's allow you to make a bootable CD. Lastly or maybe I should have mentioned this first. Make sure your drive is pinned out correctly. I'm only guessing you bought an IDE drive which has a jumper for setting the drive as a master or a slave or a master with a slave.
Jan 03, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
Maxtor Hard Drive Logo
98 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
