Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Freezer fan moaning!!
Freezer fan going slow/fast/slow etc. Nedds to be replaced? Tough job? Thanks!!
  • Robert Moller
    Robert Moller May 11, 2010
    Please provide model number of refrigerator as some of the newer units are a little more difficult for diyer.
  • GE Master
  • 43,501 Answers
Actually the job is not that hard...get on repairclinic.com and look up your model and take a gander at the exploded diagram. then you will have an idea as to where it is and how to get to it...
toal time for replacement probably less then a half hour...
heatman101
Posted on Apr 23, 2010
Low hum or buzz in fridge/freezer (mostly from the freezer side)
Hello, the solution was the ASM control circuit board, ordered one online for around $100 and replaced it
Thanks
May 30, 2010 | Refrigerators
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
Fan sounds like it runs slow, fast, slow with a wining sound. There is black residue in the back bottom of the deepfreeze.
If the black residue , is on the left , in the back , then the # 5 thermistor needs to be replaced . This is a white torpedo looking piece , with 2 white wires going to it , inside a holder at the bottom of the freezer panel . This thermistor , tells the control board , the freezer temp , and if bad , it will " lie" to the board , which can cause the fan speed to vary .
Glad you mentioned the residue with the noise . Had other questions concerning the fan speed , so now , it finally makes sence . Thanks for a complete question WITH observation .
Oct 25, 2009 | GE GSS25SGRSS Side by Side Refrigerator
GE side by side - moaning coming from freezer
Unplug and remove the rear panel in back of freezer and tell what you see. Let me know, Thanks,Sea Breeze
Jul 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model GSS22JERFBB moaning sound form freezer section
That's the fan motor. Either the fan blade is hitting something or the motor is going bad. Either is a cheap fix.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active Smart® E522BR...
Fridge is whistling
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
Jan 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
77 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
