Question about Emerson EWF2004 20" TV
Can't get channel 3
Emerson tv. We need channel 3 so we can watch on cable.
    President:
  • 196 Answers
Connect the antenna cable---enter in menu and press autoprogram.
Posted on Apr 24, 2010
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Sep 27, 2014 | Emerson Televison & Video
What channel does the tv need to be set to to watch a VCR?
Hi. It is usually channel 3 or 4. Just try setting your TV to 3 and see what happens. Make sure your TV is set to VCR.
Jul 05, 2014 | Emerson EWV603 VHS VCR
How do i change the input on my emerson ewf2006 tv without the remote? i dont have cable or sattelite or an antenna, so i wanna use my ps2 game system to watch movies for now til i get cable. cant do that...
There is one way to try. I would have your playstation connected to the A/V of your TV. Power up your game. Now try tuning your TV to channel 3 of course. Now, press channel down on TV a few times...You may get an input. I'm not sure if this will help, but try anyway. If this fails, you need to purchase a universal remote with an input selection. I recommend a Philips remote. TV remote model # SRP 1003/27. This number is located just left of the universal price code. I found this remote as one of the best. Thanks for asking and show a few hands of support!
Feb 28, 2011 | Emerson EWF2006 TV
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
My tv does not stay on channel 3,which is the channel it needs to be on to watch cable. the tv will start to make a clicking noise and then it jumps to channel 4. i have check all the connections 2 and...
That's weird...Check your cable box...I had a little switch for 3 or 4....I'm not talking about your selection on the TV...But the cable box itself....If it wants 4....Give it to it...lol..Just something to check..Good luck
Oct 27, 2017 | Emerson Televison & Video
I loss view of my cable channals after watching DVD.
if you have a snowy picture when you move around the channel selector you probably have a bad solder connectionand must have it repaired by your tv man
Dec 18, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I previously was hooked to a dish in my old location. I moved and now have cable but lost the remote and can't set up the TV. What to do?
there is a menu button, the channel buttons move you thru the menu...first setup making sure the setting is on cable...if channel 2/3/4 don't autotune in cable lineup, be sure to go back and manually add otherwise you won't be able to watch using dvd or vcr, or play video games
Jul 01, 2009 | Emerson EWF2004 20" TV
Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
May 15, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Emerson EWF2004 20" TV Logo
435 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
