I bought from radio shack one of your products which has recently stopped functioning: it was a vibration-senser put on top of a hard-wired chime that radio'd to another remote chime. Batteries were OK. I don't see that particular model shown but is it possible to buy aq replacement from you?
  • 17,970 Answers
I suggest call 1-800-843-7422 for assistence.
Posted on Apr 22, 2010
How do I disconnect the chime from automatic door .Had to cut cable as it jammed . Took out fuse but radio and clock now do not work .Can I disconnect wire from chimes .I knoe it comes from speakers .
try this
disconnect battery
undo the fuse box and look at the wires behind that fuse you pulled
check that only radio and clock wiring are fitted there
the chime may its own power source
i could be wrong
i thought chime was separate to sound system speakers
and comes from a small but loud sound device on the instrument panel circuit board ..much like a computer
May 28, 2014 | 2005 Buick Terraza
Radio in 2003 GMC Yukon isn't working
Even though it doesn't say locked, it probably is. Check your driver's manual to see how to reset it.
Jun 30, 2017 | 2003 GMC Yukon
Brake chime won't stop
the problem could be abs or just he switch behind the e-break lever. you can identify the chime put your finger over what you believe it is and if you feel the vibrations strongest there thats it. some cars have them in the radio.
FGTech Galletto 2 Master
Oct 21, 2012 | 1994 Oldsmobile 88
I have a CTP8600 Cordless phone made by Coby in 2003. The battery pack for the handset is apparently no longer charging. Coby has stopped making (or supporting) this product. I would like to replace the...
Try taking the battery pack to your local radio shack store. They can usually match the original battery pack with a new, compatible one even if they no longer make the EXACT one that came with the phone. This recently happened to me with a panasonic phone bought around 2002. phone stopped charging, no longer make the phone, etc. I went down to radio shack and they fixed me up with a new battery (not exact brand/part number as original) and it worked. Hope this helps you.
May 20, 2011 | Coby CT-P8600 Cordless Phone (CTP8600)
2007 HHR Radio and chimes not working
Check the radio fuse. As unusual as it seems, GM has started having the radio (even though not turned on) generate the chimes and turn signal sounds. If the radio fails, all the chimes fail too.
This applies to other vehicles besides the HHR. My 2003 Silverado had the door chimes fade down so I could barely hear them. The fix was to replace the radio (under warranty, fortunately...).
Mar 10, 2010 | 2007 Chevrolet Tahoe
Radio shack trc-447 cb. no controls function, radio turns on. Channel displays 8. switches do nothing,
The units have a reset code that protects the PLL brain from damage from voltage spikes. Ship it in and I'll get it back to normal function for you, providing the PLL has not been damaged.
Thanks,
Dodgem
www.Dodgem250.com
Feb 12, 2010 | Radio Shack TRC-447 CB Radio
No sound for door chimes or radio
Is the radio stock? If so have you tried getting a different OEM radio?
Jun 07, 2009 | 2004 Chevrolet Impala
Scanner won't pick up as many channels as I thought it would.Or maybe I juut don't know how to operate it
Did you get it recently programmed for your local area? Radio shack can usually do that for free, or you can purchase a data cable for the scanner from Radio shack for about $30-35 (a bit expensive, yes :| ) . I also have one of these scanners, there very nice but you have to play with it a bit to figure out how to use it's functions. :) LOL!
Jan 22, 2009 | Radio Shack Pro-96 Scanner
Passat Indicators Blowing Fuses 2005 model
It sure sounds like a short in the left signal circuit. I can't say where the wires are routed but you may have one with failed insulation or pinched under some hardware.
You could avoid repeated fuse replacement if you buy a cheap digital multimeter from Radio Shack (if you are in the US) or alternately, from an auto parts store. One adequate for this would be under $20 US. Some have a continuity checker that sounds a 'chime' that stops when the resistance level rises a bit. Since the meter could be damaged if the short clears, it would be smart to disconnect the negative side (ground) of the battery. Putting the probes across the fuse contact will simulate the fuse for this checking but it will not let your signals function. I would punch the probes into the fuse holder, put on the left turn signal and start removing bulbs and checking the routing of the wiring. When the chime stops, you have found the culprit.
Sep 19, 2008 | 1999 Volkswagen Passat
16 people viewed this question
 Grubhead
Grubhead
