Question about Dell 948 All-In-One InkJet Printer
Screen says clear paper jam, I can't find any paper in it anywhere?
4 Suggested Answers
whitetiger93
  • 141 Answers
SOURCE: dell 924
**HW support: 877-459-7298 and you must have the Express Service Code of your printer or any Dell product you're calling in so that they can route you to the right department.** Usually, if you're having paper jams, it could be a mechanical problem with the printer. Try these: - turn off the printer. unplug the power adapter for 1-2 minutes - lift the printer upside down and shake it sideways (strange huh?... usually, this helps because it can re-align those things that may not be aligned right inside the printer) - then, adjust the paper guides and use about 10-15 pieces of paper. try using the printer. if it's still the same... it really is the printer. - if it's still under warranty, Dell can replace it. This information is from Dell, try it it can't hurt.
Posted on Mar 26, 2008
Scott Ellin
  • 558 Answers
SOURCE: Paper Jam
Open the tray and cover. Look out for any paper inside the cover.
Close the cover and tray firmly. Then check for a test page.
Let me know if I can assist you further. Don't forget to vote the solution.
Regards
Ellin
Posted on Sep 26, 2008
sys_admin
  • 829 Answers
SOURCE: get a paper jam error message despite no paper in
Hi Turn the printer upside down and hit slowly to find any piece of paper then switch on the printer .
Posted on Jan 16, 2010
Why am i getting the error message * memory rx 2P Recording Paper Jam? I can t find a jam anywhere?
Delete the fax and check paper tray rollers are cleaned. May be missing feeding which mean roller can't grab the paper and machine is expecting the paper to be at a certain point and does not see (Though sensors though out the paper route thru the machine so it thinks there is a paper jam) Also mite want o clear the memory (SRAM/DRAM) will lose one touches so make sure you have list backup
Jun 27, 2014 | MinoltaFax 2600 Printer
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
Code 200.13
Replace Sensor Input Media and it should fine The part Number 40X1223 the cost around $3.60.
Apr 24, 2008 | Lexmark X342n All-In-One Laser Printer
2575 paper jam
You could try gently shaking it and see if anything falls out.
You should also try cleaning it, first maybe with some compressed air, you may have a dirty sensor or something
Another thing you should try is unplugging it and allowing it to reset.
Please let me know how the above work out and I can give you further options to try if none of them work.
Thank you for using Fixya and Have a Great Day!
Apr 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
2575 paper jam
This worked for me. If "Paper Jam" error message continues to appear after jam has been cleared, turn off power to printer. Navigate to Control Panel - Printers, right click on HP Photosmart 2570 series icon, click on Delete on drop down menu. This deletes printer from your system. Turn on power to printer. Printer will re-install (may need original installation disc, may not). "Paper Jam" error message should no longer appear.
Mar 27, 2008 | HP Photosmart 2575 All-In-One Printer,...
Xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Mar 06, 2008 | Xante CL30 HSE Laser Printer
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Dell 948 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
