Question about Poulan Garden
Need to reattach throttle cable to a poulan pro 131
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: need a diagram of fuel gas lines on a 131 poulan
Lots of research has shown a lack of diagrams on fuel line routing. Your carburetor has the purge/primer bulb on top of it. Just to help you understand how it works....the bulb uses a vacuum effect to pull fuel from the tank directly into the carburetor and the check valves in the plate under the bulb (known as the primer base assembly) push any air and old fuel inside the carb back into the fuel tank. On your model, the line inside the tank with the fuel filter on it will come out and go to the carburetor body BELOW the base assembly. The other line coming out of the tank (fuel return line) will go TO the nipple on the base assembly. The lines should be nice and soft and so should the bulb. They all have to be replaced periodically as alcohol, heat and age deteriorate them. Please post back if needed.
Posted on Nov 06, 2010
Testimonial: "somewhat usful. would have liked a diagram. Bob"
Model pp4218 throttle stuck open
I assume you are referring to a pullen pro chain saw. If so, the cable that links from the trigger to the carburetor is stuck. This can happen due to trash and dirt stuck in the trigger area, or the carburetor needs cleaning. Or the cable or wire to the carburetor is bent. See if the connection between the trigger and carb moves freely when not running.
May 02, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi, Received a used poulan we940rc with broken cable (start, turtle, rabbit). Cannot start engine. Check no sparks on spark plug? Magneto dead? Any manual so I can try to repair if not will scrap. Cao...
You can check for spark by removing the spark plug, reattaching the plug wire and grounding the plug to the head and having someone pull the starter while watching the plug. The start position on the throttle cable actuates the choke on the carb, which is pretty important for a mower with a throttle cable in order to get it to start. Get the model number off the back of the mower and take it to a small engine repair parts shop.
If really helpful, please rate.
Jul 12, 2011 | Poulan "Poulan" Push Mower
How does the throttle cable route on a poulan pro 260 42 cc chain saw
HOW DO I INSTALL AN ACCELERATOR CABLE ON MY 260 PRO POULAN CHAIN SAW?
Oct 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 220 saw starts & runs fine when finger on throttle, will not stay at idle. Rplaced plug & same issues.
All you need to do is try to adjust the throttle idle speed or else a cheat would be to tighten the cable which means the cable will be pulling very slightly the throttle which means it will remain running when u release throttle.
Nov 05, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Will not idle
May be time to get the carburetor rebuilt. Sounds like the diaphragms are not working properly to pump fuel. You may need some lubrication on the throttle cable too. A little lubrication on the throttle arm would not hurt.
Good Day.
Oct 14, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
The kohler engine on my poulan pro 42 inch 17 hp is reving way too high the throttle cable does not apear to be stuck
YOUR THROOTLE LINKAGE IS BINDIND WITH THE ENGINE OFF MOVE THROTTLE BACK AND FORTH WATCHING THE LINKAGE ON THE CARB, SPRAY LINKAGE WITH PENETRATING OIL SO IT LOOSENS UP
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
111 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
