Question about Mtd Products Yard Machines 158CC Tiller
How do I replace the pull cord on my 31cc yard machine tiller?
  • cmfillier Jan 29, 2012
    Try youtube. They have videos that help you tune an engine so they might have videos to help you with your problem. Worth a shot.
    Top Expert:
  • Mtd Master
  • 45,346 Answers
Carefully . the recoil spring will want to fly apart .
Posted on Apr 25, 2010
How do i replace pull cord on mtd 31cc tiller
Remove your recoil housing. Turn the inside to see if spring is broken. If spring is good wind it up as tight as it will go without forcing it. Once you have it wound all the way then back it off one turn or until the eyelet meets where the rope comes out. tie a knot in one end and feed through both holes. Pull the rope through till the knot is tight then attatch your handle. Once the handle is in place slowly let the rope wind itself in. pull a few times to make sure your knot is holding and reinstall on engine
Jul 16, 2014 | Yard Machines Mtd Yard & Garden Cultivator...
How to replace pull cord on mtd yard machine cultivator 31cc
-Remove the cord or rope assembly. then rewind the unit and then attach the new rope to. After install the new rope. Try to pulls out to see it will rewind back or not. If not rewind more.
Good luck
Mai
Jun 19, 2014 | Garden
How to remove the clutch?
After removing the 4 screws and clutch cover you should be able to pull the clutch assembly off with a gear puller.
Jun 28, 2013 | Yard Machines 121R 31cc 2-Cycle Gas...
Will not start
when you push the gas bubble make sure you see gas filling the two gas tubes. If not, pull the tube out of the gas tank and check the tube filter screen to see if its clogged. Also check the side filter to see if its clean. If you pulled the starter cord too much the carb could be over flooded. You can spray some starter fluid in the carb and see if it will start that way. If this is the first start of the year sometimes it needs a boost with the starting fluid.
Jun 04, 2012 | Yard Machines 121R 31cc 2-Cycle Gas...
I have a yard machines 31cc y28 17'' how do I fix the pull string it is pulled out fully
Take the top cover off, You should then see 4 bolts around the engine cover, take these out and the cord head will come of,Depending on where the cord broke is the question of using the same cord, But if you're getting a new cord you will need to thread the cord into the eye for the cord, Tie a knot to prevent it pulling apart. then tie your handle on. After this you will wind the cord up tight on the pulley and a screw driver holding the pulley from moving while you put the cord and cap back on the engine, You can then start back installing the bolts and the other cover..
Aug 28, 2010 | Yard Machines 21A240M000 Garden Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
1,074 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
